Adding power supply socket to FF
Started by DJPsychic, April 14, 2020, 10:31:45 AM
DJPsychic
Going to install a power supply jack, along with the battery snap, to my next NPN germanium FF build.
Do I need to add any filtering to circuit board?
patrick398
Probably wouldn't hurt to have a small series resistor plus large cap in parallel (smaller cap also in parallel if you want)
DJPsychic
#2
Quote from: patrick398 on April 14, 2020, 10:45:48 AM
What values would you recommend?
And is it absolutely a must or just a precaution?
DJPsychic
Only ask because space is kind of limited on my current layout. If it involves too much moving around, may just leave out. I've heard germaniums don't like power supplies. But would be nice to have the option.
Also looking at pedals like the Sun Face, I don't see any filtering
patrick398
Usual practice would be a 47-100R series resistor, 100u and 100n cap in paralell. Not sure why germaniums would not like power supply but happy to be shown otherwise
DJPsychic
Quote from: patrick398 on April 14, 2020, 01:54:05 PM
Excellent thank you
And Yes just something I've read, can't speak on it personally.
Could I get away without the added filtering or is it required?
j_flanders
Quote from: DJPsychic on April 14, 2020, 02:19:31 PM
It's not that they don't like power supplies but some people find the circuit sounds better with a certain type of battery.
https://www.diystompboxes.com/smfforum/index.php?topic=62730.msg493854#msg493854
It's not required, it will work without the filtering.
However, the power from your adapter might not be 'clean' enough which you may hear as hum.
DJPsychic
#7
Thank you (again) for clearing that up man. I'm gonna roll with out it for the time being.
Does the filtering effect tone? Spent a lot of time dialing it in  :o
Quote from: DJPsychic on April 14, 2020, 07:15:26 PM
The filtering is for the incoming power, not audio.  It won't change your tone.
patrick398
Here's a good read about power supply and filtering.
https://www.mrblackpedals.com/blogs/straight-jive/7475792-you-want-the-truth-you-cant-handle-the-truth-more-than-you-need-to-know-about-power-supplies
As Marc says, you're just filtering the power, not audio. Your wall wart or isolated power supply or whatever is taking AC from the mains, stepping down the voltage and rectifying it which means converting it from AC to DC. This process is not perfect and varies with the quality of power supply.  Basically the filtering we put in place attempts to smooth out any inconsistencies in the power supply which might create noise or problems in circuit performance.
I'm sure it's WAY more complicated than this simplistic view, but that's above my pay grade
Yes, Patrick's quite right to add some explanation.  My response was a little lite on actual information.   :icon_redface:   It's worth saying too that it's not just the gorgeous sinusoidal AC nature of the power origins that you're trying to hide, and render as perfect DC, but also any amount of other crud that may find its way down that bit of power flex to your pedal.
patrick398
Quote from: bluebunny on April 15, 2020, 10:54:04 AM
...but also any amount of other crud that may find its way down that bit of power flex to your pedal.
I think you need a plumber
DJPsychic
" I will say no more "
mozz
No filtering, you want carbon zinc battery or a high impedence power supply. The audio modulates on the DC.
