Diodes, Resistors, and Caps ONLY
Started by coot, April 21, 2020, 09:43:36 AM
coot
Hey all, complete noob question... but I want to really understand how basic components (caps, resistors, diodes) can affect tone before venturing into the complicated world of transistors, ICs, Opamps, etc.
Is that even realistic? Can I even make any effects with just those three basic parts? Or does even the most basic fuzz need a transistor?
I know that caps and resistors are passive (diodes aren't, I guess?), and have done some simple experimentation just running my signal through some (no power), but just get an apparently unaltered signal.
I'd consider myself a tinkerer, at best. Just looking for something fun and manageable to clear my mind!
coot
antonis
Hi and Welcome.. :icon_wink:
First of all, search for resistive Voltage dividers..
Then, substitute a capacitor for any of them..
hint: Capacitors exhibit frequency dependent resistance..
P.S.
Any search for high/low/band pass filters should be quite satisfactory..
rsq
Exactly ! I had fun (and learned a lot) building passive filters, using resistors and capacitors.
You can also check passive mixers and vactrol-based "passive" circuits. (you can make your own vactrols by taping a led to a LDR).
I made a cool low pass gate/vca some time ago, similar to this design :
mozz
coot
Quote from: mozz on April 21, 2020, 12:02:08 PM
You can make a fuzz with a diode.
Do tell! Any sample schems?
The diodes need to be grounded, correct?
CodeMonk
Quote from: coot on April 21, 2020, 12:11:09 PM
There was something out a few years back called Black Ice.
It just some diodes, no battery needed for an overdrive/distortion/fuzz sound (never heard it myself so I don't know how to classify it).
I googled it and it seems there are several variations of it.
mozz
#6
Just put a diode in series with your signal, heard they used to do it in basses years back. I guess you could put it from signal to ground also, just wire it up right on the output jack.
antonis
Quote from: mozz on April 21, 2020, 02:30:27 PM
Halfwave rectification..(Sounds terrible)..
Mixing it with an also halfway rectified phase reversed signal, sounds good..(Octave)
Halfwave (asymmetrical) clipping..
Sounds interesting..
(with curremt limiting resistor, of course..)
coot
antonis,
     Those sound like cool ideas... so what do I need to look for?
"halfway rectified phase reversed signal"?
I like pictures.
antonis
#9
Quote from: coot on April 21, 2020, 05:07:21 PM
I like pictures.
Me too..!!  :icon_wink:
(but from where I post it's almost impossible..)
See this: https://www.electronics-tutorials.ws/amplifier/phase-splitter.html
and then proceed to Q2, C2/3, D1/2 and R7/8/9/10 here: http://www.kobra.hr/Schematics/Octaver/Green%20Ringer.gif
iainpunk
Quote from: antonis on April 21, 2020, 05:20:09 PM
you don't need a phase splitter, you can also use a humbucker with the center tap grounded and two Germanium transistors to rectify the signal passively in your guitar. i have that on a bass of mine and it sound cool and gated.
cheers
antonis
That seems to me more permanent case than intermediate effect, Iain.. :icon_wink:
