useless question about potentiometers in parallel
Started by Dimitree, April 29, 2020, 01:15:54 PM
Dimitree
I'm wondering,
if I use a dual gang pot, one gang being 1M log, the other gang 1M rev-log, and wire them in parallel, I get a single 500K linear potentiometer?
I guess yes, but I'm not able to demostrate that with math.
If true, would it be still true in case the resulting pot would be used as voltage divider?
Kevin Mitchell
iainpunk
no, not at all. i asked myself this question once, this is the answer
at 50% rotation, a log pot has a ratio of 1-9, that means 100k and 900k on either side of the slider, that means that there is (100k // 900k=)90k in series with another 90k so 180k... the taper will be near linear but the resistance will change along the way. also, most log pots are comprised of 2 or 3 linear parts with different resistances, making the parallel resistance even more "wonky"
cheers,
Iain
cheers
