High voltage MOSFET bias
Started by EricKnabe, May 04, 2020, 01:33:01 PM
EricKnabe
So this may be my dumbest question yet, but bear with me.
If I have a MOSFET that can take up to 600V on the drain and I'm running 250V to it, but the max Vgs is like 30, then wouldn't that technically make it impossible to center bias without destroying it?
antonis
Only in case of DC grounded Sourse.. :icon_wink:
In case of Source resistor existence, you can use whatever Vgs is proper to have desirable Drain current..
edit: I might didn't get you right, so more data plz..
(like Mosfet configuration (CS, CD, CG) Drain current, desirable gain In case of CS) etc..
No. You are confusing yourself somehow.
antonis
#3
I think I got you now..
(Paul's "confusing yourself" worked as a catalyst..) :icon_wink:
"Center bias" term is refered on Drain (for CS amp) or Source (for CD amp) voltage, resulted by VCC - (IDQ X RD(S)) and NOT on Gate voltage absolute value..!!
e.g. For VCC = 250V, center bias is 125V and can be set by a 125Ω resistor and 1A current or 125k resistor & 1mA current or any other R X I combination resulting into 125..
To get the appropriate Drain current you have to choose respectively proper VGS voltage, which voltage is (ideally) independed of VCC value..
So, Gate voltage value could be 10V say, for Drain current of 10mA so you can center bias Drain with a resistor of 12k5..
https://www.electronics-tutorials.ws/amplifier/mosfet-amplifier.html
EricKnabe
Thanks guys. I've since realized that yes, I was confusing myself.
Gate is control. Drain is load. They need not be related any more than a crane's cab and hook.
