N4401 uses?
Started by coot, May 05, 2020, 10:23:09 AM
coot
I was under the impression that 4401s (and 2222s) were pretty standard transistors for simple silicon fuzz. Now, for the life of me, I can't seem to find them used anywhere!
Does anybody have a schematic for a fuzz using 4401s?
SUBQUESTION: Were I to replace a listed transistor with what I have, how would I calculate capacitance and resistance modifications for differing hfe?
Gus
You can build a Fuzz with different transistors
one of the first calculators or the first I know of on the web, click on fuzz face
https://www.diystompboxes.com/analogalchemy/emh/emh.html
Myself and other have posted about biasing FF like circuits
A post showing what adjusting the resistor values does, most of the FF resistors are part of the biasing
Don't get stuck with the 2nd transistor collector needs to be 4.5VDC
https://www.diystompboxes.com/smfforum/index.php?topic=114153.msg1058953#msg1058953
Med  power transistor fuzz
https://www.diystompboxes.com/smfforum/index.php?topic=114343.0
2N4401s should work well in a fuzz
Seach for others posts and thread at this web site. A lot has been posted over the years. IIRC Aron's 1st forum started around 1996 or maybe a little later so there have been many posts about fuzz circuits
bushidov
Also, though not as gainy as a fuzz face, a bazz fuss circuit should work too. It is pretty simple and only requires the one transistor. Just make note of the E B and C pins when whacking that transistor in place.
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
- Antoine de Saint-Exupéry
Marcos - Munky
The 2N4401 is a general purpose NPN transistor with hfe of about 300. You can use it basically in any effect that uses a 2N3904 or BC549 or 2N5088 or any other general purpose NPN transistor.
swamphorn
The peak hFE is specified at IC = 150 mA, versus 10 mA for the 2N3904, so it's optimized for higher currents.
