Debugging tool idea / advice needed
Started by utarefson, June 02, 2020, 01:19:46 PM
> Why have you added a 10k resistor to both inputs ? (why are they required ?)
The 10K pot shorts-out the signal. With the two 10k resistors the source is not loaded-down or damaged. Also the LM386 is semi-protected against unplanned large voltage inputs.
