Using a DSA to analyze the Behringer Super Fuzz
Started by aparks517, June 04, 2020, 12:50:42 PM
aparks517
The write-up I did about measuring the Tube Screamer with a dynamic signal analyzer seemed to go over pretty well here, so I thought I'd share my latest victim... er... subject... the Behringer Super Fuzz. Three separate modes made comprehensive measurements a little tedious :-\ , but I got through it and I think I found some interesting stuff for my troubles  :D . At the suggestion of one of my new Internet friends, I'm now armed with an Instrument BASIC program for summing up harmonic distortion separately for even- and odd-order harmonics, which turned out to be handy for this pedal. All the gory details are in the write-up at https://heartfx.net/sf300.html
I was reading through the documentation for the correlation option on the DSA and I think I could do some interesting measurements on time-based effects too. Is that something you'd be interested in?
teemuk
Good analysis. The unit is reputedly clone of Boss FZ-2 Hyper Fuzz, which totally explains some of your observations:
- Distortion circuit is archetypal "phase split" octaver plus clipping diodes circuit, thus abundance of strong second and even order harmonic content
- Both fuzz modes share the same distortion stage and simply employ different post distortion emphasis
- Boost feature simply bypasses the distortion stage and post emphasis
- Bass control is resonant, treble control shelving type with "traditional" Boss distortion effect voicing resembling that of poorly damped amplifier driving a speaker load. (Bass control and its range corresponding resonant frequency and treble control corresponding increasing inductance at higher frequencies).
aparks517
Thank you for the kind words  :D
You're right, that matches up quite neatly. Very interesting, particularly the reasoning behind the bass and treble controls!
Quote from: teemuk on June 05, 2020, 06:31:19 AM
