Pedal Noise Problem
Started by awgearhart, June 17, 2020, 02:59:53 PM
awgearhart
I'm building a Brian May Treble Booster with an input cap switching mod, and have run into an issue. When the effect is bypassed, the guitar signal is gone and there's a hum/buzz sound. When I turn the effect on, it is a little noisy (but this may just be how the pedal is designed).
I breadboarded the circuit before soldering and it worked excellently. I think this must be some sort of grounding or input jack issue. What's most concerning is how there is no guitar signal and a loud hum when bypassed.
I've posted a pic of the guts of the pedal as well as the wiring diagram I used for the pedal with a few adjustments:
1. I added a 1M resistor from the Pot output to ground (to help with switch popping).
2. I saw many people say to flip the orientation of the transistor (2N5088) as shown in the diagram, but it worked correctly when I wired it to the diagram.
blackieNYC
It works when not bypassed?  Sounds like the switch is wired wrong for the bypass position.
antonis
2N5088 is wired correctly as it is..
I'm with blackie for switch miswired..
awgearhart
Yep. I found the problem.
I had incorrectly wired the bypass position. Also, I changed my pot cause it seemed a little scratchy. Everything sounds great.
awgearhart
I also wired using the grounded input configuration on the foot switch.
