Am I missing a secret - any circuit with an Opamp fails
Started by Sacorus, June 25, 2020, 04:17:52 AM
Sacorus
I searched before I posted this new topic - hoping I could find an answer...
Pedals I build with Transistors work fine - be it either designed from building blocks or the occasional clone
Pedals with an Opamp in them - zero success
I use Eagle for schematics and layouts
I have tried on breadboard (just tried the Intro IC based OD before I posted this)
And build on Perf and strip board (and occasionally a bought PCB)
I have multiple choices for ICs - 741 4558 TL072etc
I have a good multimeter (Fluke) a good solder station and plenty of parts
I have had pedals with CMOS chips work and also successful builds with PT2399
Is there something that I am missing???
Probably something simple.
Get a simple opamp buffer circuit working on a breadboard and take it from there.
Maybe there's something wrong with the way you are interpreting pinouts for IC's?
Are you wiring the power pins?    You need to wire those even when the circuit doesn't show them, it's kind of understood (although some circuits can be ambiguous).
If you can't get it to work, measure the voltages on each pin of the IC and post them.  Post a pic of your board.
There's plenty of people on the forum to give you a push.
Sacorus
Not just the one board
Anything I try
example on a dual op
V+ on pin 8
GND pin4
Set up a voltage divider for Bias (virtual ground)
all checked and measured with the multimeter
Sacorus
Passes no sound
I checked the signal path from the opamp side of the input cap - signal is gone at that point
GibsonGM
I'd try a simple buffer as suggested, Sacorus.   Many SINGLE opamps like 741, TL071....V+ is pin 7. That's an easy place to make a mistake.
Try measuring right on the chip's pins (but don't short it out!) could be a bad connection at the breadboard fooling you.
It's easy to screw up pin numbers in the feedback area, too, and have R's etc going back to the wrong input...
HTH!
*****saw your last reply - check for continuity with input pin &  the input cap's leg on the opamp side. Could be breadboard...pressing on the back of them sometimes re-seats the metal clips inside...or else something is grounding out your input signal (?)
antonis
Quote from: Sacorus on June 25, 2020, 05:26:13 AM
Something weird happens here..
Does white aligator clip bring input signal on non-inverting input (pin 3)..??
If yes, I can't see any feedback resistor between inverting input (pin 2) and output (pin 1)..
(or I can't trace well the combination of 3 blue body resistors around left side of the green cap..)
+1 agree with Antonis. I think something is weird in the feedback network.
I'd pull those bits off the breadboard and stick a simple wire loop from pin1 to pin 2 (e.g. turn it into a voltage follower/buffer). Once you've proved that works, you can add the non-inverting gain feedback components back in.
Also start with just the bare essentials for gain - two resistors, or one resistor and a pot. When that's working, you can start adding in extra resistors to adjust the pot range and caps to change the frequency response etc. etc. For starters, keep it simple.
You should check pin 1, the opamp output, is at about 4.5V.
If that isn't true the whole thing will fall in a heap.
Quote from: Sacorus on June 25, 2020, 05:01:10 AM
Anything I try
V+ on pin 8
GND pin4
this is not a circuit diagram. please, PLEASE!!! like james brown said, please - draw a circuit diagram, and then show it to us. please?
" I will say no more "
Sacorus
Apologies on the delay getting this up
(Had to get some enclosures finished)
GibsonGM
Took a quick look...As drawn, the power supply appears short to ground at the 100r resistor...which also is not necessary.  But I'm sure that ground symbol there isn't real, correct?  If this is for simulation, it will cause an error.
I would change R4 to 1M.  As it stands, the gain ratio is not working in your favor.   You might take a look at this for a better understanding, in the part about voltage gain:
https://www.electrosmash.com/mxr-distortion-plus-analysis
R9, 470r...seems too low.     HTH!
Gibson, I think that 'ground symbol' thing is a +9V port - it's labelled.
If you're going to use the 100R resistor, you need a decent size electro cap across the power rails, fro your +9V to ground. Then you'll have a proper lowpass filter to reduce noise and/or hum on the supply. Otherwise, get rid of the 100R because it doesn't do anything on its own.
The rest of the circuit looks fine, but there's a lot of bits I wouldn't put in initially. I already mentioned the feedback network. I'd build it minimally first, get that working, and then add the other bits. If it *stops* working, then you know it's something you've just done and you can take a step back. If you go straight in, you know there's a problem, but it could be *anywhere*.
antonis
Quote from: ElectricDruid on July 06, 2020, 05:28:41 AM
I suggest you start with this:
Just green line short is enough..
(no reason to delete that magnificent broken elbow wiper of GAIN pot..)
@Sacorus: GAIN pot C stands for reverse-log taper mark and should come after its value..
(or else, it could be easily confused with capacitors numbering..) :icon_wink:
do you have continuity across your + and - rails...?
most breadboards have a split in the rails.....and need jumpers to connect them.
also add jumpers to the top and bottom rails. +/-
I assuming that the floaty unused half of the 4558 isn't actually left unconnected.  (Connect - to OUT and VREF to +.)
Sacorus
I appreciate the help -
i will try without the additional parts
and I normally use a 100u Electro across past the 100ohm on the supply
And breadboard rails where joined - I also checked with my multimeter
antonis
Quote from: Sacorus on July 22, 2020, 04:32:03 AM
As you like..
But Electric Druid suggestion for shorting Out and inverting pins release you form checking individual items & combinations..
(it converts op-amp configuration into a unity gain buffer so you don't have to deal with NFB/Gain loops for the moment..)
Checking all the DC voltages on the opamp pins would be a big help.
