Germanium Overdrive
Started by dthurstan, July 02, 2020, 10:40:54 AM
dthurstan
Hi
Here is another pedal I've built recently. The idea was I had some low gain AC128 transistors (~27 & 60 hfe) laying around, why not try and come up with a germanium overdrive. I watched a JHS video about stacking pedals and a That Pedal Show video about hitting a overdrive pedal with a rangemaster (to mimic a rangemaster going into a cranked amp) then put this together. So it's starts with a more full range rangemaster into a germanium ce amp then a lpb-1/ce amp to add volume after those first two stages. I like it although I think it might stray into distortion territory really.
too much whitespace = too much scrolling - down down down down across across across up up up up .... what? nothing here but white! down down etc etc ..... edit! resize! post!
but otherwise, well done. no pulldown resistor on the input cap?
" I will say no more "
antonis
Are C1 & C2 placed inside enclosure as spare parts..??  :icon_lol:
dthurstan
Quote from: duck_arse on July 02, 2020, 11:00:56 AM
fixed. Haven't noticed any popping but would be a good idea.
dthurstan
Quote from: antonis on July 02, 2020, 11:09:56 AM
Yeah, meant to draw up the bipolar supply circuit for the -9v but forgot. I'll do it at some point.
mozz
#5
Is C6 really needed or is it acting in series with the .1 before it? Think I'm gonna breadboard one of these and see what (how) low gainers work.
dthurstan
Quote from: mozz on July 02, 2020, 12:02:27 PM
You are probably right. I don't know if it's obvious but I'm a bit of a hack. I just slap bits of circuit together & give it a name.
I was surprised how good & loud low gain transistors sounded. Just bias the stages appropriately & it works.
I used a silicon stage at the end to add volume after the overdrive/distortion. That maybe distorting too, but like I say I'm a hack. :icon_rolleyes:
dthurstan
I've added the bipolar supply now.
I should probably add stuff like pulldown resistors, power filtering and protection to these schematics I'm posting.
I'm not sure with voltage multipliers (ICL7660S/MAX1044 etc) if the filtering should go before or after the IC. Since in this case you're only interested in the -9v.
Would a 1N5817 in series with the +9v mean that you get a little less out from the -9v, it does tend to be a little lower without it.
Eb7+9
... and, WHY did you use a charge-pump ic instead of just swapping the power supply wires ??!
dthurstan
Quote from: Eb7+9 on July 02, 2020, 05:59:03 PM
Hi, because I wanted to use it with a common PSU.
antonis
BY "common", do you mean PSU feeding a daisy cain or just an ordinary PSU for individual use..??
niektb
Quote from: dthurstan on July 02, 2020, 04:09:48 PM
I think you may have inversed the polarity on C2 :)
Ben N
Kewl! I'd like to give this a go, and possibly try NPN and/or different power options.
C4 is upside down for a positive ground circuit.
antonis
Quote from: duck_arse on July 03, 2020, 10:17:00 AM
Not for an down under area.. :icon_wink:
dthurstan
Me and my schematics  :icon_redface:
Quote from: antonis on July 03, 2020, 07:27:17 AM
Yeah, daisy chaining effect.
antonis
You and your schematics   :icon_mrgreen:
dthurstan
bushidov
#18
Hi D Thurston,
I liked the design, so I quickly threw it together in EAGLE and made some gerbers and a BOM
http://www.cyclone-radio.com/pedal/dthurstan_drive.zip
Schematic
Top PCB
Bottom PCB
I did add an input anti-pop resistor, a reverse polarity diode, and a bulk cap, just for kicks.
Should easily fit into a 1590B enclosure.
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
- Antoine de Saint-Exupéry
dthurstan
#19
Quote from: bushidov on July 04, 2020, 08:06:36 AM
Hi D Thurston,
Schematic
Top PCB
Bottom PCB
Nice one bushidov. Good work. Here is the vero layout if anyone is interested.
I did it that way because I had some board ends I wanted to use up.
