EarthQuaker Disaster Jr DELAY PEDAL WITH TAILS - HELP
Started by ic_, July 05, 2020, 07:33:12 PM
ic_
Hello!!
I'm working on the EQD Disaster Transport with Tails mod from
https://tagboardeffects.blogspot.com/2017/12/earthquaker-disaster-transport-jr.html
Everything seems to be working as supposed on the pedal, the effects work correctly and the tails mod too. but i hear a lot of noise, not a hiss, i dont really know how to describe it correctly but more like a white "grainy" noise sound (like rain).
I'm very new to building pedals, i would like to understand better how to diagnose problems. I replaced the chips TL072 and Pt2399, but it didn't change anything, i also checked if there was any bridges between tracks on the veroboard and cold joints, using a multimeter, everything seems ok. I tested my grounds and checked if they were ok too. I replaced some components and the trimpot but nothing changed.
I'm very new to building pedals and i know i still have a lot to learn. What may be causing the noise? What can i test or change? Someone has any tips or have built this pedal? Where should i be using an audio probe to find the problem? or what other technics can i use?
Thank you for your help  :)
andy-h-h
Hello
You may not get any help without posting photos of both sides of your build along with voltages.    ;)
ic_
hello!
thank you, i will try to get some pictures of the board and voltage measures.
Maybe an audio sample should be more helpfull..
(by guessing noise classification, e.g. shot, pop-corn or flicker noise, it should be easier to locate its origin..)
ic_
Quote from: andy-h-h on July 05, 2020, 07:49:33 PM
Hello
Here are some pictures of the veroboard.
https://drive.google.com/drive/folders/1EnhLlngtznOtgLMN9F2_XCLph8fG5JQ1?usp=sharing
And voltage measures of the ICS
TL072
1 - 4.43 V
2 - 4.43 V
3 - 4.31 V
4 - 0 V
5 - 4.43 V
6 - 4.43 V
7 - 4.44 V
8 - 8.88 V
Pt2399
1 - 5.08 V
2 - 2.5 V
3 - 000.1 mV
4 - 019.6 mV
5 - 4.23 V
6 - 2.5 V
7 - 0.75 V
8 - 0.77 V
9 - 2.5 V
10 - 2.5V
11 - 2.5 V
12 - 2.5 V
13 - 2.5 V
14 - 2.5 V
15 - 2.5 V
16 - 2.5 V
Those are normal values for the chips? this is my first delay pedal, i would like to understand better what's causing the noise, before i try to build another one on other veroboard. I'm still learning. Thank you so much.  :)
ic_
Quote from: antonis on July 06, 2020, 06:05:05 AM
Thank you Antonis, i will try to record something. its hard to describe it. not a hiss or pops or shot.
ic_
Here it is some sound recording
not the best recording, but i don't have another way of recording now.. but i think you can hear the noise sound..
I don't really know if the noise comes from mistakes that i made on veroboard or if its the chip pt2399 that has this kind of noise.. i bought them from tayda. i hope they are ok.
I can't work it out on your diagrams, but from your posted voltages, pins 3 and 4 of the pt2399 are not connected together. this might not cure what ails you, but short those two pins together so they both read 0.00V.
also - a belated welcome to the forum.
" I will say no more "
ic_
Quote from: duck_arse on July 07, 2020, 11:34:59 AM
also - a belated welcome tpo the forum.
Thank you so much for that sugestion and welcoming, I'm looking forward to learn and share on this wonderful forum :)
