Aion Blueshift - no bypass signal
Started by newjackruby, July 09, 2020, 09:00:11 AM
newjackruby
I can't believe it! I finished the Blueshift chorus, and I'm actually getting effect signal on the first try! I would have never imagined that I could finish this extremely complicated project and have it work.
BUT...there is no signal in bypass. Weird. I'm not even sure where to start with this problem due to the unusual footswitch wiring.
Anyone know? Here's the doc - schematic on page 9.
https://aionelectronics.com/wp-content/uploads/2017/06/aion-blueshift-dimension-c-chorus-documentation.pdf
Probably some wrong wiring on 3DPT switch lugs 1, 3 & 6
(no buffer Input or Output on bypass mode..)
newjackruby
Quote from: antonis on July 09, 2020, 09:51:57 AM
I am using the stock bypass (page 13). Lugs 3 and 6 are not used.
Marcos - Munky
Just to be clear, how you're naming the 3pdt pins?
Some people calls them
1-2-3
4-5-6
7-8-9
I call them this way, and if I got it right Antonis also calls them this way. But some people calls them
1-4-7
2-5-8
3-6-9
which seems to be the way you're calling them.
Kevin is clear about how the 3PDT pins are numbered - it's on page 15.  In any case, the wiring diagram on page 13 is pretty clear and doesn't refer to pin numbers.
Quote from: newjackruby on July 09, 2020, 09:55:36 AM
THen, re-re-recheck switch wiring..
P.S.
Don't post build picture for us to trace correct wiring, if you plz.. :icon_wink:
(I know Stephen will yell on me, but..) :icon_redface:
newjackruby
#6
Quote from: Marcos - Munky on July 09, 2020, 10:16:19 AM
1-2-3
4-5-6
7-8-9
1-4-7
2-5-8
3-6-9
I also think of them as 1-2-3, but the doc for this project names them the other way, which is how I've wired them. It looks to me that the 3PDT in this project is not involved in the bypass at all, but rather that this is controlled on the board with jumpers and the optocoupler. I'll double check that area tonight and report back.
Quote from: newjackruby on July 09, 2020, 10:23:41 AM
I also think of them as 1-2-3,but the doc for this project names them the other way
Communication breakdown.. :icon_lol:
QuoteSee page 15 for more information on these bypass methods.
I'm going to yell on anybody that uses numbers for switch lugs, and/or doesn't show us what has been built.
" I will say no more "
newjackruby
Quote from: duck_arse on July 09, 2020, 10:52:43 AM
[/b]
Oh no, don't yell on me!  ;D
Here's the top and bottom of the bypass section, and the switch. Difficult to photograph where the other end of the switch connections go, as this is a double-decker, but I have verified them.
I'd recommend continuity testing everything connected through the switch (from PCB pads to switch/jack lugs, not from solder blob to solder blob).
newjackruby
Well, shit. Went in and checked continuities and now I have no signal either way. I wish I knew what the voltages on all these chips should be. Think I'll stuff this in a bag and forget about it for now.
Having no signal now might be a sign of some cold solder joints.  Check out the blobby ones and reflow.  An audio probe might be helpful with tracing where your signal stops.
We should be able to work out the voltages by looking at the schematic.  I suspect the opamp in/outs will be at VR. Kevin tells you the voltage and bias points for the BBDs in the testing section.  With the accumulated wisdom around here, we should be able to come up with values for pretty much everywhere.  Would be a shame to discard!
Quote from: bluebunny on July 10, 2020, 03:22:43 AM
So plz, be our guest, Marc... :icon_lol:
well, newjackruby, from looking at the voltage measures you've posted, we can see that the unit is werking perfectly, all parts correct place and value, all wires correkt. there can't be a problem.
So Stephen, are you calling OP airy-fairy fantasist..?? :icon_mrgreen:
I just didn't want to yell on him, Antonis.
newjackruby
Quote from: duck_arse on July 10, 2020, 10:29:20 AM
Your sarcasm is neither unnoticed nor useful. No, I didn't test the voltage of all 12 IC's on these boards. Mainly because there's nothing in the doc that tells me what the correct values should be.
But I understand the dynamic here. Every message board on the internet has the one guy who fancies himself the alpha dog and takes more pleasure in sarcastically pointing out how clueless every new user is than actually helping.
I hope it makes you feel good to be so superior to us n00b plebes.   :icon_rolleyes:
Cue the part of the thread where the assistant sarcasm masters stop by with their "OH NO YOU DIDN'T!" posts.
Ah, internet.  :o
I imagine duck is PM'ing you now as I write this.   He is more of a jokester than a meanie, and is actually usually quite sensitive when he thinks he may have offended.  He has, however, seemed to have developed a bit of low patience in his quarantine, like most of us, I'm sure.  He gets upset if he doesn't see schematics ("circuit diagrams", in Aussie parlance) or measurements.  He'll calm down and make you laugh eventually.  :icon_wink:
Quote from: newjackruby on July 11, 2020, 03:27:40 PM
Do it anyway.  It's what we ask everyone and it's what's laid out in the very useful "Debugging" sticky.  We're trying to help.  When we get the voltages, we'll be able to get a bit further.  It doesn't stand on fall on whether or not Kevin posted expected voltages.  I've already suggested that the opamps will be at half-supply.  Indeed, probably anywhere that's carrying audio.  The BBDs and companders are a bit more involved (and beyond my pay grade) but there will be someone here who will know the answers.
With respect, you misunderstood the dynamic entirely.  This has got to be - hands down - the most civil and helpful forum on the planet.  My antipodean pal is not the alpha dog, and neither is anyone else around here.  He may have been impatient, he may have had a shitty day, his cat may have died - we don't know.  But he'll be back to help you as will everyone else.  But you have to help us to help you.
