Simple mixer for use with Captor X
Started by jubal81, July 15, 2020, 01:46:52 PM
jubal81
So I've got a Two Notes Captor X on the way and it doesn't have an aux input, which is a bit of a bummer since I'd like to use it to play along with songs/backing tracks through headphones.
Drew this up hoping it will do the trick, but I'm wondering what other options might be, or if there's a better way to skin this cat.
jubal81
This TI headphone amp chip looks pretty simple. Looks like I could use it for the output opamps with 39.2r series resistors.
https://www.mouser.com/ProductDetail/Texas-Instruments/TPA6120A2DWPR?qs=ojKcPFmCWSXiGd7G5JhN2A%3D%3D
marcelomd
Hi
You don't need the buffers and can mix the inputs directly.
I guess an NE5532 can do everything with one stage per side, but maybe not, depending on your headphones.
jubal81
Good advice.
Here's the latest version using the TI headphone amp chip:
jubal81
Well, I'm getting sound out of it. I guess that's a start. Level is low and it's a rather extreme high-pass filter.
