Can we solder FV-1 chip?
Started by Elijah-Baley, July 24, 2020, 01:58:55 PM
Elijah-Baley
Hello guys, it's since a while I'm thinking about to build a delay pedal more complex than a PT2399 based on I already have. I'd really really like to build something with FV-1, to get longer delay and space, cool sound. I can buy some kit with PedalPCB board.
But the tiny legs of the FV-1 make me afraid. I never soldered smd stuff.
Do somebody do it? Is it really possible solder FV-1 with a regular solder we usually have? Maybe there's some trick to do it safely.
I know PedalPCB sell PCB with the FV-1 soldered on, but it will cost to me a lot because delivery and maybe the fee, so I would to avoid it.
It's easier than you think to solder SMDs.  For ICs, I prefer a solder dragging technique where you apply some liquid flux to the board, line up the chip, then drag a giant blob of molten solder across all the leads with your iron, perhaps shorting many of them together.  Then, apply a bit of solder removal braid to remove the excess solder, clean up your extra flux, and you're done!  Takes less than a minute.
I'm assuming, of course, that you have a PCB with the pads for the FV-1 on it.  Don't ask me how to solder one to a scrap of perfboard.  :icon_razz:
Elijah-Baley
Thank you. :)
I still don't have any PCB where solder the FV-1, but I could buy it with less worries, now. I searched indeed some technique to solder SMD.
But I don't have flux, I never used it just because I use solder with a flux core, so I never need flux. I don't know I wish it will be not so bad without flux, I prefer don't buy it to use it just one time.
Ice-9
You can solder the Fv-1 quite easily with a normal soldering iron and solder. I do it by tinning pad 1 wit ha bit of solder then holding the chip in place with tweezers and then soldering pin 1 down. Make sure the chip is in line then solder down pin14. The chip is then secure in place and all the pins can ten be soldered. I dislike the method of soldering all pins in a flow and cleaning up afterward, it is just not needed wit ha 1.27mm pin spacing to flood all the pins and if not mopped up properly can leave shorts.
For a 1.27mm pin spacing IC solder each pin individually.
www.stanleyfx.co.uk
POTL
I advise you to practice before soldering this chip.
Buy some cheap smd chips and give it a try.
My first smd chip was drowned in solder =)
It's not really difficult.
mark2
Quote from: Ice-9 on July 24, 2020, 05:20:46 PM
I've done about 30 FV-1s now, and this is exactly my method too.  Even the very first one I ever did turned out just fine.
It's worth noting (since it defies some peoples' intuition) I also use a fairly large pencil or chisel tip, NOT those tiny pointy ones.
I use small (.5mm) solder which I think helps, and I always ensure I have the solder hovering near the pin, ready to go as soon as I apply heat.
And a magnifier helps immensely.
Ripthorn
I recently started doing SMD with my normal iron. I bought some inexpensive tacky flux from Aliexpress (RMA-223). I got like 20cc's for $2 USD shipped. I put some on the pads, put the chip in place, and got a little blob of solder on the iron tip and dragged across. Do that a couple times relatively quickly and it works out beautifully. The flux I have is no-clean, though you might want to clean it up on a white or other light colored board for aesthetic reasons.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
Elijah-Baley
You can get very inexpensive "SMD practice kits" on eBay which might be worth a look. They basically consist of a few dud ICs and cheap components and a PCB for you to solder them to. Some of the kits actually *do* something when you finish, but some are purely for soldering practice. Either way, it's a cheap way to make a few mistakes before you get stuck into the real stuff.
Elijah-Baley
I'll try to search something useful. ;)
Digital Larry
SOIC is the smallest thing I'd dare to try doing by hand.  Unfortunately I designed an FV-1 board with some even smaller op amps and voltage regulators.  I think I built 3 or 4 of them before I decided that hobbies should at least be marginally fun.
Digital Larry
Elijah-Baley
Do you mean it was a bit worthless to build with SOIC?
I know sometime it's hard to build something like this stuff at home, and believe me, I have huge difficults sometime: I have no right place where I can build, I have just basic tools, and cheap, in a cardbox, no much space where stock the parts, etc... but I satisfied when I can play my pedals. A delay  based on FV-1 now is what I'd like to play.
Ice-9
Just to add in addition to my method above I also use a flux pen it helps the solder flow very smoothly and helps avoiding bridging pins. Use the non clean flux pen and not a water based flux pen as the water based are known to cause problems if not properly cleaned after.
an example of the type of flux pens i often use.
https://uk.rs-online.com/web/p/solder-flux/3217289/
www.stanleyfx.co.uk
