making a Mid-Fi Electronics Clari(not) and have a question about the LDR / LED
Started by jimitrader, July 26, 2020, 03:45:36 PM
jimitrader
this is where i am at now too...This is the first one like this that i have built seems to work but..(testing mode ldr and led)  when i touch led to ground and positive pad it doesn't light up? so if i put mm in test mode I get voltage changes turning knobs..but when i hook up mm to ground and test positive led pad ..no power? so please how does the led get power? is it somehow a ground adjustment? since this is new to me i would like to learn how it works? thanks for having such an amazing site...your pedals are so fun to make and never any probs with layout
https://effectslayouts.blogspot.com/2016/02/mid-fi-electronics-clarinot.html?showComment=1595791689761#c527877121655948258
schematic
http://i10.photobucket.com/albums/a113/midfielectronics/mid-fi_clarinot.png~original
antonis
Quote from: jimitrader on July 26, 2020, 03:45:36 PM
Could you please post a draw of exactly what you're saying..??
Marcos - Munky
Remove the led and check the voltage at lug 1 of the tracking pot. You probably have to hit the strings to get some voltage to appears.
If you get a voltage reading with the led removed from the circuit, your led is probably reversed or dead.
