Adding an LED to footswitch
Started by Charvel2005, August 22, 2020, 02:20:44 PM
Charvel2005
Needing some help!
I am trying to add a LED to my foot switch for my Marshall Jubilee clone.
It uses a latched on/off switch. In the open position it is sending 7.8 volts DC down the line. (OD channel, with the LED on the head lit). In the closed position head is on the clean channel, no voltage.
Trying to get my head around how to go about this. The LED on the switch need to light up when the foot switch is in open position and getting voltage.
And i really don't want to use a battery.
Any help would be appreciated!
antonis
First of all, Welcome.. :icon_wink:
Can't figure out your particular switch but a p-n-p BJT configuration could be your solution..
(in case of, no voltage means GND or 0V - not "open"..)
Charvel2005
No idea what you are talking about!!
I can follow a schematic, bias an amp. build something...but not sure what you are describing, hence the ask for help
