What to do with Free/Floating Opamp?
Started by TySN_Sound, September 25, 2020, 03:35:20 PM
TySN_Sound
Building a buffer/splitter (1 in/2 out) with two tl072's. The first is only being used to buffer OUT 1, so the second opamp is free. Both opamps in the second chip are being used for OUT 2 buffer and phase invert.
I was curious what to do with the unused opamp.
Only need the phase invert on one of the outs. I've seen schematics with extra opamps being wired like a buffer, with the input going either to Vr or ground and the out just floating.
Why not just have all the extra pins go to ground?
Is there something else that I can use it for that I'm not thinking of?
You won't have seen the unused output just floating: the opamp would get upset.  It was more likely connected to the inverting input (like a buffer) and the non-inverting input connected, as you say, to VREF.  That way, the unused opamp is in a happy place and it won't unintentionally upset the rest of your circuit.
MikeA
#2
+1 to bluebunny, here's the reference for doing that:https://www.ti.com/lit/an/sboa204a/sboa204a.pdf
Or you can use the extra op amp half as a buffer for your reference voltage supply (Vref), if you're using one rather than a dual supply and referencing to ground.
TySN_Sound
That doc explained exactly what I wanted!
MikeA's tip is spot-on too: using it to make your VREF rock-solid is a good way to use up the unused opamp.
