HELP with "trouble with using multiple breadboards? or design issue?
Started by jimitrader, September 28, 2020, 04:22:06 PM
jimitrader
I am working on a pedal i like called the Black Magic Love pedal (link)
the problem i am having is adding a tone control section?I really like the boss hyper fuzz eq section so i have been trying to add it in on the breadboard.I also added a simple boost after to bring volume back up a little (link)everything was going great but now i have 3 bread boards and issues
1. board 1 is for the power section to make vref and vcc 9v and 4.5 v2. board 2 is the tone stack eq section3. board 3 is the boosti dont have 50k b pots so i took 2 100k a pots and added resistors to make them close to 50k..but when they are not connected yet its super loud..as soon as i connect the pots the sound cuts way down and starts to cut in and out so if you wiggle the wires it comes back loud but with a humming noise..like a ground issue and if i wiggle again goes to a quieter volume with no noise issue? not sure what the heck is going on? anyone else have this problem? i am not sure if its a issue mixing the design or the breadboards? any advise would be awsome..or a suggestion for a good eq section also...
P.S.
right after the last resistor 22k to ground original BM schematic - eq section - out to boost - back to the volume pot and out
thanks !!
Delete 22k (R4), make 470k (R2) 1k or so, delete 500k Volume pot, connect a 10k pot on pin 3 for Volume setting and come back and report..  :icon_wink:
P.S.1
Don't know your particular EQ loss so maybe 10dB boost aren't enough..
P.S.2
Your chosen booster couldn't be considered as the state of the art..
jimitrader
Quote from: antonis on September 28, 2020, 05:33:16 PM
P.S.1
P.S.2
ok... will do thanks!
jimitrader
P.S.1
P.S.2
hey that worked good thanks !! do you have a better boost you could recommend?
also do you know about taming the sizzle while distortion is on 10? lol...
if i could just tame it a bit..it goes fine till the very end of the sweep (distortion knob) then sounds nice and distorted but a little sizzle or crackle not sure how to describe? have you ever made this one? hey thanks for the tips!!!
11-90-an
flip flop flip flop flip
Quote from: jimitrader on September 28, 2020, 11:22:00 PM
Never dealt with LM386 in a distortion circuit.. :icon_wink:
But, IMHO, Distortion pot should work better in case of lug3 connected to pin1 & lug2 (wiper) connected to pin 8, with lug1 disconnected from GND..
P.S.
On booster posted by 11-90-an, you better replace 330k (R2) with a 1M trimmer for better gain setting..
jimitrader
Quote from: antonis on September 29, 2020, 04:31:17 AM
P.S.
I tried it out... was i supposed to leave pin 1 and 8 connected?
i didn't like the distortion sound it produced this way? so i put it back and now the strange noise is gone? hmm
