Yellow Mullard OC44
Started by Smeddling, October 07, 2020, 04:22:03 PM
Smeddling
Hi Everybody
Today I was given 6 of the subject transistors. They were 'harvested' from a board found in a skip!
I have tested them on my DCA 55 an all look good. Two measure around 40 and the other 4 measure 85, 102, 110 &180. Leakage is no more than 35uA.
I understand that these transistors were used in the Rangemaster.
My questions are:
Are they genuine?
Is there another circuit (fuzz/boost) that these will be good for?
Does anybody know the difference between the yellow and black transistors?
Are the yellow ones particularly unusual/ scarce?
Cheers all
BR
Stewart
Electric Warrior
They sure look like the real deal and measure just as expected.
Some of the black variants hardly leak at all and I think not all of them cover such a wide range of hfes. Other than that it's just a visual thing.
You could try them in a Fuzz Face. Most of your transistors should be gainy enough to bias well despite the low leakage.
dfx_pedalpcbs
Genuine defo. What a find!
In my experience the yellow jacket ones are normally a bit lower hfe than the black equivalent. These can sell for £10 to £15 each on the ebay last time i checked.
Smeddling
Thanks folk.
I think I'll have crack at a rangemaster circuit and a fuzz face then 👍
Cheers
BR
Stewart
dfx_pedalpcbs
What was the board from any identification marks on it?
Smeddling
Quote from: dfx_pedalpcbs on October 09, 2020, 09:38:42 AM
I didn't find the board personally. It was possibly a radio as the guy who skipped it converts old radios into fancy lighting. I've told him to give me the guts in future, just in case!
BR
Stewart
kaycee
Quote from: Smeddling on October 08, 2020, 06:47:13 PM
Thanks folk.
Cheers
As you have 3 transistors left, might I suggest the Selmer Buzz Tone. It runs at 3 volts from 2 AA batteries, but is plenty loud enough. An added emitter bypass cap of 22uf on Q1, switchable, makes it a boost and a proper fuzz. I have found these very forgiving of tolerances in transistors.
aron
I just built a Fuzz Face using some of the OC140/CV7112 that I had left. Sounds great!
Smeddling
[/quote]
Thanks Kaycee. What sort of gains are required Q1-Q3?
Cheers
BR
Stewart
kaycee
I usually run lowest to highest gain. Ideally, something around 60 - 90 for Q1 and then 90+ in the last two.
mozz
Want to trade for any SFT352's?
