Generating LFO for PT2399 with an Arduino
Started by niektb, October 17, 2020, 02:34:04 AM
niektb
So, I'm designing myself a PT2399 pedal (which is nothing fancy sound-wise but with a RGB and a footswitch I hope to allow for some deep-editing without the need to open it up and flick a few dip switches).
Now, I'm using a MCP41050 (50k digipot) and wired the modulation just like in the Taptation: putting a mosfet (shunted with a depth pot) between the digipot and ground
But I wondered the following: Do I need to bandlimit the LFO?
I've generated a (for now a triangle) wavetable of 1024 steps and step through it with a simple timed function that's set to a sample frequency of 250Hz, so I'm not afraid of aliasing. However, if I would switch to a square wave (which has much more harmonics), the LFO would extend into audio range... As I'm modulating delay times (and hence pitch), doesn't this cause audible FM distortion?
How do I solve it? Additive Synthesis? External RC-filter?
void wp_inc() {
  wp = wp + (1 / mod_speed);
  if (wp > 1023)
    wp = wp - 1023;
  if (wp < 0)
    wp = 0;
// Triggers every ~4ms
void taskMod(int id_)
  uint8_t _val = pgm_read_word_near(wavetable + (int)ceil(wp));
  analogWrite(pin_delay_mod, _val);
  // fade the led if in the correct mode
  if (smode == SMODE_MOD)
    analogWrite(pin_rgb_b, map(_val, 0, 255, 0, 64));
  wp_inc();
Also, a different (but related) question: I've read that this form of modulation can cause a tempo offset... How can this be solved?
Lastly, I've seen people on the internet (such as https://github.com/ElectricCanary/Bontempo) that can 'calibrate' the pedal but I can't figure out how this works... Can anybody explain it to me?  :D
Thanks in advance! ;)
Quote from: niektb on October 17, 2020, 02:34:04 AM
Of course. Isn't that kind-of the point?!? It's not "distortion", it's "modulation". ;)
If the delay time changes, then the "tempo" of the delay changes. It doesn't change the tempo of the incoming signal. This gives a strange effect. If you modulate a PT2399's delay time / pitch with a slow sine or triangle wave, it sounds like everything is speeding up and then slowing down again, but in fact the underlying tempo doesn't change. Just the pitch and tempo of the echoes.
It's not the same as the synth "FM versus PM" case, where one can cause a pitch offset and the other doesn't. The maths is not the same.
Anything that *doesn't* use the pin 5 "clock output" on the PT2399 (or alternatively the audio input and output) isn't "calibrated" in any meaningful sense. It's an "open loop" solution, which is to say, it sets a value and hopes the chip responds according to the datasheet or its own internal assumptions. Neither of which may be the case.
In order to "close the loop" and actually calibrate the chip, you have to set a value and then measure the result. That can be done by setting the pin 6 value and then measuring the clock at pin 5. Or you can set the pin 6 value, and then ping a signal through the delay and measure how long it takes to arrive at the output. The pin 5 output on the PT2399 is a horrid waveform and needs cleaning up, but it's still easier than the second solution. The "calibration" comes when you adjust the values you put out based on the results that you saw. Without this, there is no calibration.
The Bontempo link you posted puts *the human* in the loop, and gets you to adjust the delay until it matches the flashing tempo LED. It then stores the offset that was required for that delay value, so it can repeat it next time. It says that it does this ten times, so I would expect ten values spread across the full range of delay times it can handle. The offsets for in-between delay times can then be worked out by interpolation, which should be reasonably accurate. It's not the greatest, but if you're careful with your calibration, it should be ok. Still, it depends on *your* accuracy, not *its*, which seems like a design weakness to me.
HTH,
Tom
Fancy Lime
The pitch changes of modulated delays are an electronic form of the Doppler effect. Anyway, not important, carry on.
Cheers,
Andy
Sweetalk
If you already have an arduino in the project why wont' you discard the digipot and use the pwm to manipulate the time and the modulation. You can easily adjust the pwm frequency above the audible range and no audio artifacts!. There's a pwm library around (can't remember where) that I use that does this.
I've done this technique and works fine, the pwm output it's the delay time from the pot + lfo offset (you can play with additive or sustractive lfo offset). Also check the electrosmash site that has some info about arduinos and pt2399.
niektb
Quote from: ElectricDruid on October 17, 2020, 08:00:53 PM
HTH,
Tom
Thanks for your response Tom!
So you're saying that it's not a problem that the LFO waveforms extend into audio range?
I had a RC-filter on the MOSFET-gate and it feels definitely cleaner than without, but maybe I'm hearing the PWM  ???
I'm still debating whether or not I should keep the digipot... (or maybe even ditch the tap tempo all together) I'm reading that the digipots are a pain because of their wide tolerances...
The ElectroSmash Time Manipulator uses a Controlled Current Sink with an opamp and a transistor, does anybody have experience with the accuracy of that approach?
P.S.: I absolutely love the rotary-like sound I can get from this chip. Put some Pitch Shift and some reverb onto it and melt away!
Quote from: niektb on October 22, 2020, 06:25:06 AM
I don't think it's a problem, no. The "LFO modulated sound" that you expect to hear will include some FM effects, but that's a part of that sound, not some kind of error.
Quite possibly. A single-pole RC won't reduce the PWM level much unless it's miles below the PWM frequency. What PWM frequency are you using? The standard Arduino Analogwrite PWM is only a few hundred Hertz, iirc, but you can change it.
That's similar to what I tried. It works fine. PT2399's vary, so accuracy is mostly about getting some feedback so the processor knows what it is doing. There needs to be calibration of some type for really accurate results.
niektb
Aaah okay!
I had an RC-filter that was at a (admitted, way to low) 16Hz cutoff, whereas the PWM frequency was 490Hz. I removed the RC filter and bumped the PWM to 31kHz (which was much easier than I anticipated :))
Maybe I'll experiment later on with the the LFO sample rate or some additive synthesis (to supress aliasing) but for now that's no longer a concern :)
But would you say that the CCS gives improved results compared to the digi-pot? any measurements you did by chance?  :icon_mrgreen:
Another semi-related question! I'm using a J201 to implement a Tails bypass but I'm getting loud pops when switching the effect in and out! I used the configuration found in http://www.valvewizard.co.uk/smalltimeschem.jpg except that I'm using the Arduino to supply 5V (rather than 9v)... Anything I forgot?
anotherjim
I don't think the VCO output is a all that bad  - it's just a problem to get a good look at it with normal test equipment and probes. However, the VCO can exceed 20Mhz which is probably too fast for an MCU to deal with directly - although some counter external inputs may have a prescaler but you would probably have to include some C code to set it up. An external prescaler would have to be a 74HC binary counter/divider.
I have tested the output from a 74HC counter, and I have seen a stable expected result on its slowed down outputs, so it should be workable.
I suppose you would need a Frequency/Period counter library to measure the VCO.
https://github.com/avandalen/avdweb_FreqPeriodCounter
How you line this up with actual delay is another matter. I think the PT2399 delay line has something like 44100 bits (it's a 1bit memory) but I don't know if it handles 1 bit per clock period or some binary division of that. At least you could check it out in part by first measuring the VCO to show numbers over the serial monitor while twiddling the pin6 resistor.
Quote from: anotherjim on October 24, 2020, 05:56:08 AM
No, it's not *too* bad. It rounds off quite a bit at the high end, so feeding it to a Schmitt input is a good idea.
Yes, I used an internal prescaler to reduce the counter rate when I tried it.
I don't remember it being too difficult. It was a question of working out whatever the magic number is. That depends on how fast you count your tap tempo period among other things (it's rarely convenient to count in milliseconds, for example - 1000? What kind of number is that?! 1024 is *much* more like it!). The details required are up on my site:
https://electricdruid.net/useful-design-equations-for-the-pt2399/
niektb
#9
Quote from: ElectricDruid on October 22, 2020, 08:33:55 AM
I tried swapping the digipot out like in the time manipulator must I be doin something wrong... I can't get long delay times, if I set the pwm too low it simply cuts out... and it's noisy as hell... And it modulates badly... Still my PWM frequency is set at 31kHz.
Digital Larry
I don't see any filtering on the mod PWM.  Is that intentional?
Digital Larry
niektb
Quote from: Digital Larry on October 27, 2020, 12:51:16 PM
I tried filtering when I still had the digipot, but it didn't create a lot of difference (except for some slewing in the waveform). The PWM frequency is wel above audio range :) (could still be useful for noise suppression)
Nevertheless, it isn't the cause of my current issue as I also tried to connect R30 directly to ground (therefore omitting the whole modulation thingy)
anotherjim
I don't think a TL072 is the right part for the job. It's common mode input range doesn't include the negative supply (0v in this case)
Try an LM358, or if you want to be modern, any CMOS rail to rail amp like a TLC272 etc...
Instead of combining mod and delay control to pin6, you can split them -  so basic delay controlled by pin 6 and modulation by wiggling Vref pin2, although that might mean not having Vref available for any external circuits.
Quote from: anotherjim on October 27, 2020, 05:44:56 PM
+1 agree with this. The TL072 won't cope with the input being so close to ground, and its output can't go close to ground either. It's an audio op-amp and it expects signals to float around that mid-point voltage. Push it hard to the rails and it just clips.
niektb
Thanks a lot! I have a TLC2272 somewhere around so I'll try that!
Does it matter a lot whether I use a BJT or a MOSFET? Should I tried to drive the output of the op-amp blow 0.7V(ish) when using a BJT?
anotherjim
Ideally, PT2399 pin6 would read about 2.5v throughout the delay range. When trying to get the shortest delay possible with a low resistance, it will be seen to pull down that voltage. Not the ideal condition but unavoidable if you want to attempt chorus. However, there should always be some resistance connected out of pin6 toward 0v so the control should not be capable of directly pulling pin6 to 0v.
Your control can go down to 0v (and it would be awkward to scale it to work otherwise), but I'll suggest you don't need a transistor there. Leave the opamp as a buffer and fit a fixed resistor to pin6 - start with 1k. This connection will either boost or reduce the influence of the modulation control. Higher voltage from the PWM will give longer delay.
niektb
I'm not sure if I understand what you're saying, where do I need to connect the op-amp to? in-between the 1k resistor and the modulation mosfet? How does this work when the MOSFET is conducting?
anotherjim
I was thinking of using the opamp to adjust the delay set by the lower Mosfet circuit. So the opamp would just supply another resistor to pin6 similar value to R20 providing a parallel adjustment. But thinking about it, that way of opamp connection would be better providing modulation which is the wrong way around.
Also thinking about it, I don't think the transistor in the opamp feedback loop can pull pin6 to 0v unless it goes faulty.
So as you were - apart from a more suitable opamp type!
niektb
Hahaha alright then!
But would there be any functional differences between a MOSFET and a BJT?
anotherjim
Well, I think most single MOSFET's have a higher gate turn-on threshold voltage compared to a BJT base-emitter, but the MOSFET has a high input impedance so doesn't need a buffer to drive it.
