Help needed to trace the audio path for debugging
Started by THEZED, October 24, 2020, 08:53:56 AM
THEZED
Hi guys, I built an overdrive and after a couple of days, it stopped to work. I'm trying to debug the bitch by using an audio probe, but I'm not sure about the audio path to follow.
In the attachment, I have enlighted the very first part of the signal path, can someone be that gentle to continue the path?
Thank you!
GibsonGM
C3 to pin 3 of IC1A....R9 to pin 5 of IC1B; C9, C10, C11.
HTH
iainpunk
FF = feed forward (signal path)
FB = feed back path
TN = tone / filtering
X = where no signal should be present
good lick
cheers, Iain
cheers
THEZED
Thanks guys!
Problem solved! I've got this rattling (grounding) noise with a very low sound out of pin 1 of IC1 and I was worried about some troubles in that area, finally I inspected the area under the pot and there was some solder residue (solder dust+flux) hanging between pins 1 & 2 of the IC, bridging them and grounding (I guess) pin 1.
Now the pedal is back to life!
Thank you!
antonis
Quote from: iainpunk on October 24, 2020, 11:10:53 AM
FB = feed back path
good lick
cheers, Iain
IMHO, you better reconsider part of purple (X) path of signal "absence".. :icon_wink:
