Trouble with JFET Boost Circuit
Started by mrahc_jftd, October 25, 2020, 05:48:21 AM
mrahc_jftd
Hi everybody! Complete newbie here.
I'm having a bit of trouble with this circuit. I had it going once, but now I've rigged it up again I'm just getting nothing.
I feel like maybe I'm not successfully getting power to the J201, I rigged up a quick LED off to the left and it didn't turn the light on, so it leads me to believe I've not got power going into the circuit.
As I'm not sure and I know the people here are absolute legends, I thought I send over the schematic and photos to see if anyone here can spot where I've gone wrong!
Thanks guys. Hope you're all keeping well ❤️
antonis
What's the purpose of +9V wire on 3PDT switch lug 7 (upper right..) ..??
niektb
I'm not well-versed in reading color codes from a metal film resistor but is R4 1 milli Ohm or 1 Mega Ohm? (since m stands for milli and M for Mega)
antonis
There aren't commercially availiable resistors of 1m (0.001Ohm) value..
Steben
Greetings!
Welcome. In Dutch there is a saying: "Meten is Weten" = to measure is to know.
Do have a multimetre? Can you check voltages?
It is just as possible a solder joint is mechanically ripped with moving the circuit.
Steben
Quote from: antonis on October 25, 2020, 06:20:13 AM
LED power connection probably.
antonis
Quote from: Steben on October 25, 2020, 06:57:02 AM
If so, black wire goes to LED anode, which anode is also connected to "somewhere" when effect bypassed (red wire on lug 9)..
Steben
Quote from: antonis on October 25, 2020, 07:05:48 AM
Yes, that wiring might be a problem. It can connect power to gnd for example... We can't see where the wires go of course.
mrahc_jftd, can you show where the wires go?
mrahc_jftd
Probably not the wisest of methods but the set up of the footswitch was just one I spotted on Google images and I just ran with it!
But to answer the question as to where that wire's going - it's going from the positive lug on the DC Jack, to that top right pole, then the middle right lug (LED) goes into a 2.2k Resistor, into the LED anode (just soldered on component to component) then it is attached to another wire, which runs to ground.
I'll grab a photo of it asap, apologies. But I threw the explanation in to hopefully illuminate where that's going.
see in the highlights, the breaks in the blue/red continuity indicators? that break indicates there is no continuity in the middle of the busses, you need to jumper across each break, or move your power connections to the other end of the board.
[this exact problem caught me this week - but without the coloured lines.]
" I will say no more "
mrahc_jftd
Quote from: duck_arse on October 25, 2020, 09:27:06 AM
Mate!!! Thank you so much. This was exactly the problem. Worked swimmingly afterward!
Thanks everybody I appreciate you all & wish you a happy day/night.
keep the problems this simple and we'll get along fine.
