Dallas Rangemaster: voltage collector
Started by ricci, November 13, 2020, 06:55:56 PM
ricci
Hi everyone, I finally managed to build myself the Dallas Rangemaster treble booster with negative ground and with an OC44 germanium transistor and standard values except for the 3.9K resistor which I don't have and which I replaced with a 3.5k resistor. The pedal works but on the collector of the transistor I measure 1.38 V, so very far from the 7 V required, but it works. Given that I am using a Spot one as a power source. What can it depend on ?
Thanks in advance
iainpunk
try replacing the 68K with a 100K trim pot!
also, what are the base and emitter voltages?
cheers, Iain
cheers
ricci
#2
Vbase =8,66 V
Vemitter = 8,93 V
Vcollector= 1,43 V
Why do you suggest me to replace 68k with 100k ?
Edit:
ok ok, now I reread and I missed that you were referring to a 100k pot, in order to find the resistance you need for the bias.
willienillie
I think your measurements are all upside down.  9V - 1.43V = 7.57V.
iainpunk
Quote from: willienillie on November 13, 2020, 08:56:53 PM
i think exactly the same!
cheers
ricci
what do you mean ?
Quote from: willienillie on November 13, 2020, 08:56:53 PM...all upside down. ...
One usually-authoritative site, ElectroSmash, gives it that way.
https://www.electrosmash.com/images/tech/rangemaster/dallas-rangemaster-bias-points.png
https://postimg.cc/Yvf3pycL
Which may be another reminder to say WHICH plan you are working from.
1.5V drop in Rc is not wrong.
How bad does it sound??
Big Monk
Quote from: ricci on November 13, 2020, 06:55:56 PM
Thanks in advance
How are you achieving negative ground but using the OC44?
"Beneath the bebop moon, I'm howling like a loon
ricci
Quote from: PRR on November 13, 2020, 09:54:09 PM
I will check the positioning of the multimeter better. The sound is ok.
ricci
Looking at the survey posted by PRR, i repeated the measurement and found that the voltage collector is -8.44V with respect to + 9V and 1.56V with respect to ground. Tell me if that's okay.
antonis
Arithmetically, it's wrong.. :icon_smile:
(8.44 + 1.56 result into 10V..)
Measure your power supply voltage..
ricci
I noticed it and it is also curious because the output voltage from my power supply is 9.50 V. I don't know what to say. Does perpetual motion exist?
Steben
For a "clean" amp, drawn this way, we might like 4V across the collector resistor for equal swing both ways.
For a "distortion" amp we offset it so sonic damage happens sooner and happens longer. 2V, 1.5V, maybe little difference.
To play, add a 50k or 100k trim pot in series with that 68k resistor and turn it.
ricci
I soldered a 100k pot instead of 68K (not in series with this one) and a 10k pot instead of 3.9k but I get at most -5.60V, putting the black tip on the collector and the red one on -9V. But is there a way to fix the bias by ear?
mozz
#16
Positive ground circuit. Red goes to ground. Measure collector voltage with other lead. Set 3.9k. Adjust 100k pot.
EDIT: now i see you used a pnp but use negative ground. I have to ask why as there are npn germaniums around.
ricci
So, correct me if I'm wrong, so...in the case of negative ground, like mine, it should be the other way around and that is that black must go to ground and red to collector. I had to invert the leads otherwise the multimeter gives random values.
willienillie
#18
You mentioned in your first post that you built it negative ground with a (PNP) OC44.  There's more than one way to do that, but basically you've built it "upside down" when compared to the original, positive ground PNP circuit.  If you want to compare your collector voltage to an original that has roughly -7 volts relative to ground, you should measure between your transistor's collector and the "far end" of the emitter resistor, which in your case is supply (nominally +9V).  That's why I said "9V - 1.43V = 7.57V" above.  If your actual supply is 9.5V or 10V, it doesn't change much.
Swapping the meter leads should only change the polarity (+/-) of the readings.  It doesn't really matter, we know the polarity is correct for the way you built the circuit.  It's the |absolute value| that you're looking for.  But even that doesn't really matter either, the "target" collector voltage is just a ballpark number.  Now that you have a trimmer to adjust bias, you should set it by ear to whatever bias point sounds best to you.
ricci
So, if I understand correctly, what matters is whether you like the sound regardless of the value of the resistors.
