Volume drop and weeping sound from Punk Repeater
Started by ghiekorg, November 24, 2020, 10:23:04 AM
ghiekorg
HI guys :)
Here is the layout: https://effectslayouts.blogspot.com/2014/11/dirty-punk-repeater-delay.html
Schematic SHOULD be this one, i haven't found a better one:
It works, the repetitions are kinda clean but i have 2 problems:
1- a really big volume drop when engaged. I used everything as layered out, i just changed the Q2 (BC459b) for a 2N5089 and i used 2 resistors (1M+330k) instead of the 250k i didn't have.
2- a sweeping sound when rotating the time knob: https://www.youtube.com/watch?v=UI5qxT5BFUo&ab_channel=ghiekorg (volume up :) )
Can you help me fix this?
Thank you
11-90-an
My guess would be a flipped transistor
Weep sound is normal...  :icon_mrgreen:
If that doesn't work then pictures plez... :icon_mrgreen:
flip flop flip flop flip
ghiekorg
Nope :D
QuoteWeep sound is normal...  :icon_mrgreen:
So much? 0.0 i mean, there is a constant whistle
QuoteIf that doesn't work then pictures plez... :icon_mrgreen:
of the board? i would have to disassemble the pedal as i kept the wires super short  (i can take pics of the solder side though)
I was thinking maybe there was wrong (or something to be add) in the schematic (like something to push the volume up, addind a vol pot and some filtering session to filter the whistle) :/
antonis
#3
Shouldn't an electro cap (10-47μF) be connected between pin 2 (Analog reference voltage - Vcc/2) and GND (Analog - pin3)..??
11-90-an
#4
QuoteNope :D
Just to get it straight, the perf layout showed the wrong orientation of the BC549. It is actually the correct pinout for a 2N5089 though... :icon_rolleyes:
QuoteSo much? 0.0 i mean, there is a constant whistle
Oops... didn't really hear it too well... :icon_redface:
Here's how the pedal should sound like... https://www.youtube.com/watch?v=a-aDx46PMaU (skip to 4:08)
Quoteof the board? i would have to disassemble the pedal as i kept the wires super short  (i can take pics of the solder side though)
yea the board... but I think other forumites could come up with a solution without looking at component side pictures so maybe solder side will do for now... :icon_mrgreen:
QuoteShouldn't an electro cap (10-47μF) be connected between pin 2 (Analog reference voltage - Vcc/2) and GND (Analog - pin3)..??
No cap across the 5V rails isn't good either.
anotherjim
The sweep whine would be expected with that design. It does almost nothing to prevent it. This might be deliberate, but I don't know why you'd want it to do that. Maybe I'm just not punk enough!
If you have a 9v battery snap to 2.1mm DC adapter, try powering it with a battery that way and see what happens to the noise.
