Applying Graphics and Text to a Textured Enclosure
Started by tlite, November 29, 2020, 11:30:02 AM
tlite
Googled around but the only thing I found was using vinyl letters with a heat gun.  Anyone have any good techniques for applying graphics and text to a textured metal enclosure?  I'm using this one for what it's worth...
https://www.taydaelectronics.com/hardware/enclosures/1590b-style-1/copper-hammer-125b-style-aluminum-diecast-enclosure.html
iainpunk
have you considered stencil and paint?
or just paint freehand?
i guess that's the easiest way
welcome to the forum,
cheers, Iain
cheers
Freehand with paint markers is what I've done in the past (on a Hammond textured black enclosure).  I suppose another alternative would be a faceplate.
i think John Lyons (Basic Audio) was just using water slide decals on the hammered texture, paint, powder coated enclosures he was using.
You can see more examples here;
https://www.guitarpedalx.com/news/gpx-blog/basic-audio-compact-pedals-a-to-z--28-fantastic-flavours-of-fuzz-since-1998
With stencilling even on flat surfaces measures beyond just the stencil are needed to prevent seepage under the stencil. Could be a major challenge with the heavy texture to prevent seepage.
dave
anotherjim
There is a decal softener that model kit builders use to get them to lie tight over details like rivets and panel lines. An example would be Microscales "Micro Sol". Don't know what the active ingredient is.
http://www.microscale.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=MI-2
Quote from: anotherjim on November 30, 2020, 01:31:32 PM
Vinegar
If you use vinegar to soften a decal, it may initially bubble and make the decal look ruined.  Don't panic though.  It will smooth back down.  You can also add the vinegar to your soaking water if you prefer.
Quote from: EBK on November 30, 2020, 01:32:30 PM
Vinegar
Always wondered how dilute those costly mini bottles were, i have the  Micro Set. A 3litre (3000ml) jug of 10% cleaning vinegar costs me $4.50cdn, a 30ml bottle of Micro Set from Amazon.ca is listed as $22.16cdn, i didn'y pay anywhere near that at a local brick and mortar. Amazon.ca can be quite the joke...
https://www.amazon.ca/Microscale-Industries-Micro-Setting-Solution/dp/B0006O9K4W/ref=pd_lpo_21_img_1/134-2484414-2938918?_encoding=UTF8&pd_rd_i=B0006O9K4W&pd_rd_r=a00c5fe4-08e5-4e7a-bfd4-305905fa54b8&pd_rd_w=xXiwY&pd_rd_wg=nPsxy&pf_rd_p=256a14b6-93bc-4bcd-9f68-aea60d2878b9&pf_rd_r=TGFY27B0YMNPDSGE3F4K&psc=1&refRID=TGFY27B0YMNPDSGE3F4K
Need someone to test and find the Micro dilutions.
More thoughts...
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/20/t/176734.aspx
iainpunk
another option would be to use stamps, like analog man and JHS in the early days
cheers
cheers
tlite
Thanks, all.  I'd considered paint, but my drawing skills are terrible.  I've used waterslide decals mostly for other pedals, but may just go the stamp route.  Assume you add clearcoat over the stamp?  (Or paint, or whatever?)  Thanks for the warm welcome and ideas.  Appreciate it!
iainpunk
yes, i used 2 layers of a cheap clear satin spray lacquer over my stamped items when i stamped a bunch of tools for scouting
we have a set of 12mm and size 16mm alphabet, all lower case, and i used the normal black ink pad that came with the stamps.
you could go on the internet and order a custom stamp with your logo or any other graphic you want.
cheers, Iain
cheers
merlinb
#10
I thought about this once and wondered if you could use custom 'temporary tatoo' decals, because they're very thin and designed to go on your gross lumpy skin. However, the setup cost for getting my own 'tattoos' printed was too high so I never tried it.
Quote from: merlinb on December 01, 2020, 09:49:11 AM
I thought about this once and wondered if you could use custom 'temporary tatoo' decals. However, the setup cost for getting my own 'tattoos' printed was too high so I never tried it.
Reminds me of the no-film decal product/process I mentioned a while back.  Fantastic results.  Not sure how well it would work on a textured surface though.
https://www.diystompboxes.com/smfforum/index.php?topic=36392.msg1175495#msg1175495
(I can't believe I described a point during the pandemic as "a while back".  The Before Times is getting so far away.)
MikeA
If you do try waterslide, along with the softener, give it a bake when it's dry, I find that helps it to lay down and adhere.  You can go to 300 degrees F over powder coat, 200 degrees over paint.  I give it 30 minutes at temp, then let it cool to room temp in the oven (1-2 hours.)  Let us know what you try and how it works!
tlite
10-4!  Will do.  Now I'm tempted to try the temporary tattoo thing as well.
Quote from: merlinb on December 01, 2020, 09:49:11 AM...wondered if you could use custom 'temporary tatoo' decals, because they're very thin......the setup cost for getting my own 'tattoos' printed was too high...
The racket seems to have changed. I know nothing about tatts but got a price of $20/sheet delivered, with my own "art" and a text, die-cut.
