Controlling two attiny85s with one footswitch
Started by patrick398, December 12, 2020, 03:44:52 AM
patrick398
Quote from: pruttelherrie on December 20, 2020, 12:45:33 PM
Actually, you could try that first yeah!  After all the setup, the modeswitching could be as simple as
if(mode1) {
  pinMode(1, INPUT);
} else {
  pinMode(1, OUTPUT);
If that doesn't work, you'll have to turn off the interrupts in mode1 and then turn them on in mode2, something like
if(mode1) {
  TIMSK = TIMSK & ~(1<<OCIE0A);              // Disable interrupt
  GIMSK = GIMSK & ~(1<<PCIE);                // Disable pin change interrupt
} else {
  TIMSK = TIMSK | 1<<OCIE0A;              // Enable interrupt
  GIMSK = GIMSK | 1<<PCIE;                // Enable pin change interrupt
Read up on 'bit manipulation' to learn how & why this works! For example (quick google) https://www.avrfreaks.net/forum/tut-c-bit-manipulation-aka-programming-101
If I had a Christmas card list, you would have just made the cut! Thanks so much for that man, looking forward to trying it out. And I'll try and wrap my tiny mind around bit manipulation. I've always thought I should be manipulating more bits
pruttelherrie
