Clean Squeeze Compressor 2020
Started by rankot, December 15, 2020, 01:16:39 PM
I built this one long time ago, and always liked it. Based on Afterlife/Flatline, it was actually the only one opto compressor that I built that worked as expected. It is very nice, and has full wave rectifier, so almost any vactrol can be used. This is the original schematic:
After some time, I decided to try to mod it a little. DISCLAIMER:I still didn't try anything of this, just made a concept schematic, so I must ask you to take a look and give me your suggestions. This is the modified schematic:
And PDF: https://docdro.id/dN96skN
So, those are the changes:
  • added JFET buffer in front
  • added switch to choose between compressor or expander (it actually connects LDR in parallel with R1)
  • switch to work as feedback / feed forward (not sure if this will work)
  • "low pass" switch (when open, only highs pass to envelope detector)
  • HP/0/LP switch (another variant, this one can pass full band, lows or highs to env. detector, will use either this one or previous one)
  • Attack pot, I presume it will change the speed at which filter capacitors will charge
  • Attck switch, to choose different filter caps
  • Release pot, I presume it will change the speed at which filter capacitors will discharge
  • Threshold pot, I presume it will change the LED current
  • MOSFET based compression indicator (PRR shown something like this long ago)
  • or simply parallel LED indicator
  • and finally, another dual op amp to make Vref more stable and, if needed to make an output buffer / volume control at the output.
So, what do you think? Any obvious mistakes?
:EDIT: Please note that I used BJT opto symbol for LDR opto and I have three different JFETs in input buffer simply as a placeholder for different pinouts.
Quoteadded JFET buffer in front
Why would a FET op amp need a FET transistor in front of it? Is it to buffer the feed forward option?
Quoteswitch to work as feedback / feed forward (not sure if this will work)
I'm not either, and I'm not sure if it's needed ;) What do you want out of the feed-forward option? That tends to be more of a studio compressor thing, not a guitar pedal thing. Obviously, a big generalization. The worth of a great "one-knob squeezer" like the original you showed (assuming it sounds good, I haven't heard it) cannot be overstated, especially for a guitar pedal.
Quoteif needed to make an output buffer / volume control at the output.
Not needed.
That BJT optocoupler in the schematic is an LDR in real life?
11-90-an
Cool ckt... :icon_biggrin:
I don't have any germaniums or schottkys so i can't try it on the breadboard... yet
+1 on not needing an output buffer...
flip flop flip flop flip
Quote from: garcho on December 16, 2020, 11:32:08 AM
Exactly. Wasn't sure how it will behave when using feedback option, so I put this buffer. Will do no harm.  :icon_biggrin:
That's the point. I wanted to promote it a little - so not only for guitar use. We have a small home studio and this could be handy.  :-[
Not needed.
Yes, LDR really, but had no symbol for that, so used this one. I'm planning to use few different models, until I find the one which works fine and IS obtainable. So maybe NSL-32, or even home brew, who knows?
