Madbean Collosalus Capacitor Question
Started by dfx_pedalpcbs, December 26, 2020, 07:33:37 PM
dfx_pedalpcbs
Im looking near the sweep section of the 117 flanger clone by madbean, Does C13 & 14 have to be 15uf, can they be any other value? What effect do they have on the sound?
njkmonty
11-90-an
#2
Quote from: njkmonty on December 26, 2020, 09:24:06 PM
arent they they speed caps?
Yes they are... since they are in parallel series they hav an equivalent value which would be 7.5uF which seems to be a less common value... you could get away with using a 10uF and a 33uF capacitor (which will give you around 7.6uF) instead of the 2 15uF's.
You can always change the value of the capacitor, just note the minimum and maximum speed of the LFO will change... smaller capacitor, faster speed, bigger cap, slower speed. (I think)
flip flop flip flop flip
GGBB
They are in series not parallel - and opposite polarity. This combination is bi-polar - 7.5µF. You can jumper one and use a bi-polar cap - 6.8µF is close if you can find one but that's far less common that a regular 15µF. As mentioned, 10 and 33 works but 33 might not be any easier to find than 15. Keep in mind that at 20% tolerance, 7.5 becomes anything between 6 and 9. You could probably get by with a bi-polar 10µF if you don't mind losing some of the fastest settings (and gaining slower ones).
If they are significantly different (10u and 33u) the little one gets most of the voltage swing. Since the voltage here *reverses*, this may be a significant reverse-polarity on the smaller cap, and maybe shorter life. Not that the cost of 10uFd will kill you, but Murphy says it will fail at a Bad Time.
11-90-an
Quote from: GGBB on December 26, 2020, 11:54:27 PM
oops... forgot my terms.. my bad   :icon_eek:
Testing mad bean capacitors, 43  beans in every micro-Farad.
Using 4.7uF + 10uF paralleled polars on each side is a straight forward way to use off the shelf parts - despite using a lot of caps.
Plenty of combinations of *parallel* *bipolars* can nudge up to 7.5uF,  6.8uF + 680nF   or  even 6.8uF + 1uF many other close combos.
Quote from: Rob Strand on December 27, 2020, 03:11:13 AM
but Rob, you have the wires connected and the plunger DOWN. what happens when you pull the plunger up?
easiest would be to use a 6u8 [bipolar] hard wired with another 6u8 [again bipolar] switched parallel - get faster and slower, with band spreading.
" I will say no more "
iainpunk
QuoteTesting mad bean capacitors, 43  beans in every micro-Farad.
nice to know, if i'm ever out of coffee, ill crush some capacitors.
a big @ss resistor to ground in between those two caps keeps them alive longer. around 10M should be nice.
cheers, Iain
anotherjim
I think if you used a 10uF pair and upped R22 to 10k, you'd still get a decent range of speeds.
Quotebut Rob, you have the wires connected and the plunger DOWN. what happens when you pull the plunger up?
It's one of those press shots - always something wrong.
