Neo Vibe power
Started by Mcentee2, December 29, 2020, 01:26:16 PM
Mcentee2
I've read through the forum on the neovibe, and scanned the info in RGs and GGG pdf docs.
The Neovibe I have just picked up seems to have its power supply wired up across PCB points O and J, rather than K and J.
The +ve is to J, and ground is to O - which I think is PCB ground anyway - , so only the positive side is going into the DB103 rectifier.
So...
Is this still ok, or for any reason not?
Does the voltage supplied to the LFO/Bulb still have it's diode drop(s), if so how many/much?
More generally, if I rewire to terminate on J and K, both sides of the rectifier, and can then choose AC or DC PSU, is it better to have a higher than 18v DC PSU, say 24v to account for the drop?
If it's an 18v AC, then IIRC it will end up a couple volts more anyway.
Either way, seems the supply to the audio side is regulated to 15v anyway.
Mcentee2
Oops, replied to myself by mistake!
Kevin Mitchell
#2
Forgive me if I'm confused, but doesn't that make it a half wave rectifier? With DC there would actually be less voltage drop. With AC there would be a slight drop.
The drawing suggests >17 volts for the lamp. I wouldn't stray too far from that without taking the lamps rating into consideration.
Mcentee2
Quote from: Kevin Mitchell on December 29, 2020, 02:48:07 PM
Not as confused as me :)
When it arrives I'll take a close look and measure with a DMM what is going on re voltages, but am more interested in that pair of connections before I even plug the PSU in!!
Mcentee2
So now I'm trying to find a suitable 24v DC PSU.
The only one I can find is the EHX, but that is only 100ma - is this enough current to power the Neovibe ?
Kevin Mitchell
I want to say yes. The last one I had built was fed 9 volts DC rated at 100ma to a LT1054 charge pump - worked perfectly fine. Perhaps it depends on the current draw of the lamp used.
