Embarrassed into finishing my Klone
Started by stallik, January 04, 2021, 08:51:35 AM
stallik
Having seen that Mark has now finished his 20 year hyperflanger build, I was embarrassed into finishing this.
Been on the shelf for about 5 years when I made the enclosure and a pcb. Can't find my original documentation so picked up new pcb's from Fuzzdog and wired them to fit the enclosure
Worked first time even though the 12v zener in the PS section is still in the post somewhere. Sounds much the same as my Mosky golden horse which cost me £15 new inc. postage and relegated my build to the shelf for so long. That opinion might change when I can get a little volume going
FuzzyFaceFuzz
stallik
Thank you. I'm really pleased with this one. Very transparent and dynamic
Hope you're ok Kevin.
Good job mate. What rig are you using it with please ?
Rich
stallik
I'm ok Rich, hope you are too.
I'm using a wet/dry rig. Overdrive/distortion into both amps, modulation into one. Sounds huge even at home volumes. (I know, all the gear, no idea but it's keeping me sane under lockdown)
Using overdrive set to give me clean when tickling the strings and umph when hitting it harder - I play with fingers. I have 2x TS & a Mojomojo but the Klone does this better for me. Distortion without as much compression is the only way I can describe it
Might have to build one to try with my rig then.
Thanks. I'm fine mate.
