Midiclock generator device
Started by hgamal, January 07, 2021, 03:21:06 PM
hgamal
Hi sirs,
I have developed a small pedal to generate MIDI clock messages. The device can accept tapping from its own device front push button or by MIDI control messages controller generated by an external controller. The device can tab an external pedal using the two optically isolated switches available.
The hardware and the code are totally described on the link below.
https://github.com/hgamal/midiclock
I've developed a menu system based on u8glib that can be used in other projects too.
The device is not fully tested, but it seems to be working.
I have not projected any PCB board, and I really do not know if I will.
I hope this project can be valuable to someone.
Haroldo Gamal
