1st time build - glitching, dying sound at less than full volume - transistor?
Started by tefanone, January 17, 2021, 07:17:57 AM
tefanone
Hi all,
First build and have read the common faults that will inevitably occur with such forays into building.
I've used exact matching components, checked the joints (yes I know some are a bit messy) but have v little / glitchy output at low volume and gain, only sounding viable when vol and gain are maxed.  Seems like it is a biasing issue.  I've checked all the other components which match their stated values.
Details as per the reporting format as below.  Those two resistors seem to be the culprit, unless I am missing something...
1.  Interstellar Overdriver clone, PCb bought on eBay
2.  Schematic (parts list) emailed by the seller, as per the picture
3. Adhered completely to the layout, including exact values of components
4. No modifications
5. Polarity as per the schematic, I don't believe it has been hacked to work with negative ground
6. It powers up fine but is glitchy at low gain or low volume (fades out quickly), improving only at max gain and volume
Voltages:
C1
: .547
: 0
Q1
C: 0
B: .547
E: .049
R2
: .545
: 9.1
R3
: .049
: 9.1
C2
: .545
: .049
Q2
C: 0
B: .547
E: .058
R4
: .547
:  9.1
R5
: .058
: 9.1
C3
: .545
: .058
Q3
C: 0
B: .547
E: .058
R6
: .547
: 9.1
R7
: .547
: 9.1
R1
: 0
: 0
R8
: 0
: 0
R9
: 9.2
: 9.2
C4
: .058
: 0
C5
: 9.1
: 0
D1
A: 9.35
K: 9.32
GibsonGM
Hi Tefanone, welcome!    In order to help you out, we need you to provide some info about your build. It could be biasing, yes, but there's no solid way to know without some measurements.
Please read this thread, and do your best to post the info requested back here :)    https://www.diystompboxes.com/smfforum/index.php?topic=29816.0
tonyharker
Hi tefanone, What exactly is it you are trying to build.  Did you get it as a kit or just a bare board and bought the components separately.  You could have faulty components Do you have a schematic?
tefanone
Thanks for the replies, just updated my original post.  Even if I can't get this working it has been a useful learning experience for a newbie!
In answer to the question above: I bought the board on its own and then separate components.
GibsonGM
The voltage on D1 suggests a problem; you should read 9v on the + side and nothing on the other.  It is there as a protection for reverse polarity...remove it and see what happens (hey, the damage is probably already done, LOL).  Do NOT get + and - power leads confused when you try it or you WILL destroy the transistors.  But right now, they have no voltage at the collectors, indicating a problem upstream.   Reflow the sketchy solder joints visible in the board bottom pic, too, before trying it...just a thought.  No schematic = hard to say, but the gnd side of the diode shouldn't be hot!
Actually before removing it, check for continuity between + and - with that function of your meter or measure resistance (ohms)...should not have continuity.  If you have continuity, remove D1 and check again.  Don't wreck the solder pads...
antonis
Quote from: GibsonGM on January 18, 2021, 04:37:12 PM
I beg to differ with your Highness, Sir..
Particular effect DOES call for grounded Collectors.. :icon_wink:
(reverse active mode..)
GibsonGM
Quote from: antonis on January 18, 2021, 04:49:41 PM
Ok...I am not familiar with the thing (no schematic).     What about 9V on both sides of the clamp diode?
tefanone
Hi all,
Thanks for your input. I swapped a couple of components around but I think resoldering each join helped. Itn now works perfectly, as does another simple build following the same treatment. Onwards and upwards!
iainpunk
great to hear that it works,
bad solder is often the culprit of non working pedals,
cheers, Iain
cheers
