HUM/BUZZ when DC connected, why?
Started by Luca1997, February 01, 2021, 03:31:35 PM
Luca1997
Hello guys, that's my second build (same pedal as my first build actually, this one is for a friend ;D)
So, the pedal luckly sounds when in bypass and when turned on. The problem is:
Whitout power adaptor, zero noise in bypass mode. When DC plugged in, low buzz in bypass mode. When effect turned on, louder buzz.
My thoughts:
I don't think the problem is the power supply, because my first pedal works perfectly whit it.
I didn't try the pedal inside the box but, again, my first pedal sounded right when i tried it out of the box.
Maybe the filter cap is bad? (How can i test it? Sorry for the stupid question, but as you can see i'm a beginner  :icon_lol: )
What else can i check? Thanks!
Marcos - Munky
Quote from: Luca1997 on February 01, 2021, 03:31:35 PM
Well... I won't take any conclusions just based on this. Maybe you got lucky to not having so many electromagnectical fields around the first pedal when you tested it, and now got the bad luck to have those em fields.
I test my circuits outside the boxes on my pc desk. For some circuits, it's a matter to move it a bit to the side to get from pretty quiet to noisy due to interferences that cames from my pc. And for one specific build (okko dominator clone), removing the box lit was enough to get lots of noises.
Btw welcome to the forum!
iainpunk
#2
welcome to the forum,
could you post a more close up picture of the solder side of the PCB's, the one you posted is a bit shakey
i generally have a huge amount of noise on my work desk, especially when the o'scope is on as well.
the noiselessest place is on my bed (boxspring)
cheers, Iain
I should also check for proper polarity of  C12 & C16..
Luca1997
Here's the back of the pedal!
I've tested the pedal always on my bed because i can lay down all the cables (didn't know that the bed reduces buzz, nice to know!). Anyway, i'll test it tomorrow inside the box!
Can i post a link to youtube (private video) to show you the problem?
iainpunk
QuoteCan i post a link to youtube (private video) to show you the problem?
yes, there is even a dedicated youtube button above the green smiley, but the text is gray, and the logo broken.
beds only reduce humm when its a box spring, since its a big metal cage, shorting out nearby radio signals. just like placing your radio on a metal park bench, you'll lose some signal. a box spring isn't grounded, but it does take out a part of the noise, my laptop has almost no wifi in the middle of my bed, but all bars on the corner.
cheers, Iain
Marcos - Munky
Btw you can mount the pots directly to the board, if you get the ones with long lugs. Since you're using short lung pots, you can use a leftover lug that you cut from a resistor/cap/diode. Just be sure the back of the pot isn't touching the solder joings or else it'll short lots of stuff.
Luca1997
Thanks for the advice Marcos! I didn't find long lugs pots.. but i'll definitely use some leftover lugs from resistors on my next build, since wire isn't that comfortable to cut and strip so short..  Anyway guys, i've soldered the battery snap and ZERO buzz when powered with 9v battery.. I think i'm gonna buy a lot of 'em 😂 thank you all again for your answers!
Marcos - Munky
So your buzz may be related to the power supply itself... which may be related or not to the fact the circuit is outside an enclosure. I'd still test the circuit with the same power supply after box it.
