Looking for help wiring an order switch into looper
Started by edgyswingsetacid, February 08, 2021, 12:03:35 PM
edgyswingsetacid
I'm using this wiring diagram to make a 2 loop with master bypass but I really want to add an order switch between the two loops. I have a 3PDT order switch breakout board from pedalpcb but I'd like to add an LED to indicate when they're switched.
It is a rare occurrence that someone would need to be able to flip the order of two loops within a tune.  IN which case, a 3PDT toggle can do the order flipping and the position of the bat handle can show you what comes first, without the need for status LEDs.
BJM
There's a schematic from General Guitar Gadgets but that works with a 4PDT.
