Is this possible? (Multiple footswitch question)
Started by Kevin.Ian.Common, February 10, 2021, 07:01:29 PM
Kevin.Ian.Common
Hello!
First post here, and I have a question.
I have not been able to find an answer via the web, so this may not be possible. I figured, this is the best place to ask directly.
I was wondering if it was possible to have 3 footswitches controlling three different circuits, but only one effect turns on at a time. Example: FS 1 is on, and when FS 2 is engaged, FS 1 turns off--without tap-dancing gymnastics.
Thank you!
iainpunk
if you don't mind a logic circuit, Jfet switching and buffered bypass, its quite doable, with true bypass, probably not.
cheers
cheers
A car radio does that. 5 buttons. Say News, Sports, Talk, MOR, Rock. Press Talk and the Rock stops.
Today the buttons cue a processor to work e-Switches. But in the old days a mechanical interlock popped-out all buttons except the one being poked.
Kevin.Ian.Common
Quote from: iainpunk on February 10, 2021, 07:36:05 PM
cheers
I'm incredibly ignorant to this. Any schematics?
Phoenix
#4
True bypass can be easily done with relays.
Quote from: Kevin.Ian.Common on February 10, 2021, 10:05:10 PM
A flip-flop chip like a CD40175 or similar would do it if you're averse programming, but the du jour is a microcontroller which can do the same job with fewer parts. The Arduino platform is a good way to get started in microcontrollers with minimal barriers to entry, with the compromise of being larger and more expensive than a small PIC or AVR (for context, an Arduino Nano clone will only set you back a couple of dollars).
There was a thread here a while ago about a Mesa Boogie amp that does something like this. The circuit for it is quite clever (if pretty wasteful!):
This was the thread:
https://www.diystompboxes.com/smfforum/index.php?topic=125995.0
(Edit:fixed schematic link)
webberfx
#6
it is definately easier to do it using relays, momentary switches and a microcontroller like arduino, attiny or a PIC. i built one a couple years ago for a bass pedals with a fuzz, overdrive and a bass booster, if memory serves me i used a modified version of the Coda bypass code and a PIC12F675 an 3 relays.
BJM
I never built something with relays before but with relays would a combination of one footswitch with a few rotary swithces work? Something like this:
Not quite the answer to the question but in theory you could switch two different combinations on/off.
webberfx
so have you figured it out? if your interested i wrote up a program for an attiny85 that controls 3 relays that could work for you.
