FV-24. FV-1 based pedal.
Started by deadastronaut, February 15, 2021, 10:48:43 AM
niektb
Quote from: stallik on November 29, 2022, 04:06:24 PM
So, I've had this board for a year now and only just started populating it  :icon_redface: Have a few parts on order but am looking forward to going down this rabbit hole in the new year.
With zero live experience but a little time playing with SpinCad, I have a question. This board is mono using the left output from the FV-1. Would it be possible to use the right output and the relevant circuitry after it and (perhaps using dual pots) create a stereo version usable with a dual amp setup? As I'm not using the FV-1 daughter board, there should be enough room to mount another board above the chip and still keep the same size enclosure.
Or, are patches which use such stereo effects going to be too limited by the processing power of the chip?
You can also put in a feedback loop, perhaps with some clipping diodes to get some crazy effects :D
stallik
Thanks for the replies guys.
Seems to me that if I were to introduce a daughter board for the right channel of the fv1, I wouldn't necessarily have to use it on every patch. So far, I've only played with SpinCAD but some of the stereo patches I've put together sound promising though I've no idea how they would fare in real life.
I think this rabbit hole is going to be fun - it's going to be too cold in the workshop for woodworking till spring
