My univox super fuzz pedal kit won't work
Started by snow123, March 09, 2021, 04:57:33 PM
snow123
snow123
Quote from: Kevin Mitchell on May 05, 2021, 11:02:37 PM
Can you send me a link to where you had sourced the 2N2222A transistors?
There are photos on google showing mixed info. I'm wondering if the pinout varies between manufacturers. At this point I highly recommend you first hand verify the pinouts.
And again, address the solder joints. Practice makes perfect just don't spend too much time in one spot or you'll lose another pad.
https://www.amazon.com/Pieces-2N2222-Transistor-Through-2N2222A/dp/B07R4PFTSF/ref=sr_1_5?dchild=1&keywords=2n2222a&qid=1620322958&sr=8-5#customerReviews
pretty sure these are the ones i got
snow123
the pedal now lets through a VERY weak signal to the amp. but its only audible when the gain and volume is maxed out. but it doesnt let anything through when turned off
Kevin Mitchell
Do you have a multimeter with a diode test function? Try my suggestion on the previous page to verify the pins.
Since they're unbranded there's no way to find the applicable datasheet. So let's be sure we have the pins correctly. Then we move forward!
snow123
yes i do have one with a diode tester. and how would i test it? like where do i put the leads and whatnot
Kevin Mitchell
Quote from: Kevin Mitchell on May 06, 2021, 09:41:14 AMWith NPN transistors the forward bias of base to emitter is greater than base to collector.
In diode testing setting, put the black probe to the base lead - we know it's pin two in either variant here. Place the red probe on pin one, record the reading. Now place the red probe on pin 3 and record the reading. The higher reading is the emitter.
I wrote that trying to follow this
https://www.electricaltechnology.org/2013/03/how-to-remember-direction-of-pnp-and.html
snow123
ok i got basically the same results as they got doing what they did in that article
Kevin Mitchell
Quote from: snow123 on May 06, 2021, 03:05:23 PM
So what's the verdict?
snow123
Quote from: Kevin Mitchell on May 06, 2021, 03:52:31 PM
i guess the ones im using are pnp then.
Kevin Mitchell
andy-h-h
Quote from: snow123 on May 06, 2021, 06:01:19 PM
2N2222 transistors are not PNP, they are 100% guaranteed to be NPN.
Kevin Mitchell
I very much suggest playing with your multimeter. Look up YouTube videos if it helps. Measure any parts you have lying around and understand what's what. I went back and seen that your meter has a transistor test function. Work your way to that. Learn about polarity and the basics so folks can help you out more adequately!
I can't tell you how many times I hit a brick wall simply because I didn't understand something. But once I can grasp what it is I'm seeing, better questions start to come to mind and I can communicate better. There's awesome folks here who enjoy helping and will continue to try and steer you in the right direction.
One final suggestion, don't box till it rocks.
QuoteWork your way to that. Learn about polarity and the basics so folks can help you out more adequately!
I think the OP needs to state the problem again.  I read over it and get lost in the all the detours.
One other point, the audio probe doesn't necessarily have to produce a signal at every point in the circuit or on every pin of a transistor.  How much signal you get depends on the specifics of the circuit.
QuoteSix EBC variants-- are any missing?
If you stick specifically to the P2N2222A it's only one variant.
but yeah, over the whole family of "2222" devices you have to be careful about the part and package number details.
snow123
Quote from: andy-h-h on May 06, 2021, 08:49:32 PM
o. i just saw the thing that said "BC 557 is a PNP Transistor" on the article so i assumed that the ones im using are pnp. my noob-ness is showing alot now
snow123
Quote from: Rob Strand on May 06, 2021, 09:40:25 PM
the issue is that the pedal cant get a full signal through when turned on ore off rn. at first it would let the dry signal through when off but now it doesnt do that either.
Quote from: snow123 on May 07, 2021, 01:06:20 AM
Shall we plz proceed to signal trace..??  :icon_mrgreen:
