VREF is way too high
Started by mark2, May 11, 2021, 11:11:55 PM
mark2
I have a voltage divider (between 8.9V and GND) and expect the VREF to be ~4.5V, but it's reading 8.3V.
I'm wondering if anyone can give this a second set of eyes and tell me if you see anything boneheaded I did that would pull it up that high.
Edit: 1. Ignore the clip/RIN mixup, that's not on the real board.  2. And I've done a variation of this circuit quite a few times without problems, so it's possibly an assembly problem but boy I'm pulling my hair out on this one.
antonis
R9 wrong (very high) value or "open"..?? :icon_wink:
(in case of "open", your DMM impedance sets the voltage divider lower part resistance..)
One odd thing about your schematic is there's ground symbols with and without "GND".
Are you sure the two grounds are connected together on the PCB?
mark2
R8 and R9 are correct, that's the first thing I checked :)
The GND inconsistencies in the schematic didn't make their way to the PCB.
HOWEVER... in checking out the latter I realized I may have reversed my opamp. So I'll go fix that first and check. Given that the opamp is one of very few things connected to VREF I think we may have found a winner.
Thanks! I'll report back.
Edit: by the way, I couldn't find any orientation markings on this TL074CDT at all. No dot, no half moon. I'm just relying on the orientation of the text printed on it.
Phoenix
Quote from: mark2 on May 12, 2021, 11:57:37 AM
CDT, that's a SOIC package, the side with pin 1 is bevelled.
mark2
I hadn't noticed the bevel marking before; good to know!
And fixing the orientation of the opamp fixed this issue.  On to the next.
Thanks everyone!
