New pedal build...noob questions, enter at your own risk
Started by setzer2, May 30, 2021, 01:42:08 AM
setzer2
I am getting back into making pedals and have been looking at some of the great PCBs that have come out since I last made pedals around 2008-09. Looks like things have come a long way. I am gonna try my hand at building AionFX's Refractor but had a few questions.
With the Superbright LED's from Tayda, what would be a good value instead of the 4k7 resistor listed in the parts list to tone it back just SLIGHTLY to be bright but not blinding as all of the reviews show.
I can't seem to find any wiring harnesses like AionFX's kits come with, does anyone have any recommendations for these or which parts would be needed to make these myself? I like the clean look they offer.
Thanks in advance!
Welcome to the forum!
Quote from: setzer2 on May 30, 2021, 01:42:08 AM
You might simply want to try a few (bigger) resistor values beforehand (you won't find any resistors labelled "good" :icon_wink:).  Just connect battery to resistor to LED to battery.  You could probably do this entirely hand-held.
stallik
Seems excessively ocd but I used to pop a trimmer in series with a 4k7. That way, I could adjust all the pedals to have the same brightness. The 4k7 remains as insurance against popping the led.
I only stopped doing that because I picked up a box of maybe 1000 super brights in mixed colours for a fiver on eBay . They all seem to be about the same with a 50k
" I will say no more "
setzer2
Thanks for the replies! I edited the post and got rid of most of the questions I originally posted after doing just a BIT more research on my end.
Radical CJ
WoundUp
I'm thinking so. Lol. I have blue painters tape over most of mine(all pre-built). It tones down the brightness without blocking the light completely.
On the Fuzz Face I'm currently building, I was just going to keep increasing resistor value on the breadboard until I saw something I liked lol. Seems like the easiest thing to do.
Not trying to hijack but I just thought of something. Does it matter where in the circuit you put the LED? Can you put it right before the battery so it's before/after everything?
the led and its CLR go between supply and ground. all supply is the same - all ground is the same. the only difference is where you place it on your drawing, and where you place it in your build, but unless you've done something wrong/un-orthodox, the led doesn't know where it is and there can be no different placings.
eightsevenzero
Want to chime in with something, if you're looking to build a good amount a resistance substitution box is an awesome minimal investment for this and so much more. 👍🏻
Marcos - Munky
Quote from: Radical CJ on May 31, 2021, 09:45:20 AM
I usually use 3k3... Am I the only person who enjoys bright LEDs!?
I use 4k7 for mine. It's a bit annoying if I use a white led and this resistor value, but I rarely use a white led.
:icon_eek:
Quite possibly, yes. But it's ok, I don't think it's illegal. Just deeply weird. :P
