Sansamp Bass Driver distortion only
Started by ghiekorg, June 08, 2021, 02:33:53 PM
anotherjim
ghiekorg
#21
hi everyone 😊
I managed to finish it! here is the last image
here is the printable PBC: https://www.dropbox.com/s/ciooon75inu58wg/na%20cafonata.pdf?dl=1
here is a clip https://youtu.be/qs_0qFrFoFE
Cheers and thank you for your help 😊
Edit: there are a couple of errors: drive 3 and 1 has to be flipped. Drive 2 goes to drive 1.  (if I am right 🤔)
I used: drive 100k inverted log (thanks for the tip!), volume 100k Log, Blend 100k Lin
sergiomr706
Hallo, Heard the YouTube demo, sounds really great. would It be possible to share the values of the layout components? Or a definitiv schematic? That would be ace. Thanks a lot
ghiekorg
The values are exactly the same you can see in the schematic (lite version) and I used 50k for the presence. If it's not clear I can make a list when back home
sergiomr706
