Tonepad Corral CE-2 issue
Started by Cloudbrush, July 10, 2021, 08:40:22 AM
Cloudbrush
Hi all
I have tried to make a CE-2 clone using the tonepad pcb following the document here http://www.tonepad.com/project.asp?id=53
Unfortunately it is not chorusing, just clean signal through both off and on. The trimpot does not seem to have any effect.
I have taken some figures here
Battery = 8.96V
IC1 IL4558N
1=6.94
2=6.94
3=6.85
4=0
5=6.91
6=6.93
7=6.93
8=9.10
IC2 TL072
1=2.5-6.6
2=c. 4.5
3=6.5-5.3
4=0
5= c. 4.5
6=3.83
7=3.4-5.1
8=9.00
IC3 MN3007
1=9.00
2=4.7
3=4.2
4=0.6
5=0
6=4.5
7=1.67
8=1.67
IC4 MN3101
1=8.97
2=4.5
3=0
4=4.69
5=0.3
6=7.87
7=c. 2.7
8=0.6
Q1
E=5.51
B=4.3
C=8.85
Q2
E=5.8
B=5.72
C=8.83
Q3
E=5.57
B=4.65
C=8.81
Q4
E=3.35-3.64
B=3.21-3.47
C=8.80
Q5
E=0
B=0.4
C=7.09
D1
1.53-1.63/8.5
D2
2.59-2.65/6.99-7.05
I would be very grateful for any help figuring out what is wrong
Yazoo
Do you have another MN3007 you could substitute to see if that is the problem. There are a lot of fakes on sale. I have been caught out a couple of times with this chip.
Cloudbrush
I do have another, having tried it I have the same result. I did get both from the same supplier at the same time though, so if one is bad perhaps both are.
Cloudbrush
Sorry to drag this back up, I just wanted to record for posterity that the MN3007 chip was the issue and a replacement I got from a different shop has the effect working like a charm, in case anyone is having similar issues to mine and finds this thread.
Thanks Yazoo for your advice - it was very helpful
