SI/LED/GE on/off/on switch clipping concept correct?
Started by aviherman5, August 01, 2021, 03:46:44 PM
aviherman5
Hey guys!
I had a concept I wanted some feedback on.
My idea is to have a switch for SI/GE clipping and a no clipping position on the switch. Then the signal would run to always-on led clippers. My understanding is that if a signal is already clipped at a lower forward voltage, (.7 for SI and .3 for GE) the LEDs (1.7 ) won't clip at all and the signal will remain unchanged. Is this correct? This would allow a 3 position on/off/on to give me: SI/LED/GE. Is my theory correct?
Thanks for everyone's help in advance!
aviherman5
digi2t
#4
Just an idea...
If you want to switch between three different clipping options, you can use a DPDT on-on-on switch. Since there are two different types (Type A or 1, and Type B or 2), you can use the following configurations;
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Quote403. That's an error.
Your client does not have permission to get URL /proxy/1X-nNYaf0V8bE0pofdBSfxWbA0coUbO40iEu5nkhF0m6V--IsNP2LJg_wMzG7EC-q3kFw2uzBXFK9WlGoQyUWLeRw-LeJCJGVlbnclwFdcDlrR8f-9nfN90 from this server. (Client IP address: 2001:8003:22d0:4200:4a18:76be:a463:834d)
Forbidden That's all we know.
that's a quot from the people at googoo when I try to see your image, digi2t.
" I will say no more "
digi2t
Forbidden? Doesn't that make a tasty fruit!
Fixed.
Thanks duck.
Dead End FX
Fancy Lime
Quote from: digi2t on August 01, 2021, 09:20:45 PM
Just an idea...
However, the version of the OP also works and on/off/on switches cost a fraction of on//on/on Z-switches, at least from my sources. Just in case that is important.
Andy
Just an idea...
+1 agree with what others have said. This works fine, but it's over-complicated compared to using a simple on-off-on SPDT.
Still, if you'd got one in the parts box and not the other, it would probably make sense.
