proco rat vero clone noise issues with gain past 12 o clock
Started by snow123, August 10, 2021, 10:05:25 PM
snow123
I built a vero proco rat using the layout below, and for some reason i get a high pitched squeal when i turn the gain up past halfway, and i also get some weird tone suck with that, and turning the filter knob down increases the volume of the squeal.
And here's the insides of the pedal:
also, im using a 33pf cap instead of the 30pf, and im using a 2n5457 instead of the 2n5458.
GGBB
Sounds like feedback oscillation - try keeping the input and output wires well away from each other and from the circuit. A shielded input wire might also help.
idy
The "filter" control on a Rat works "backwards" of a normal tone. CW=less treble, CCW=more. So when you turn it "down" you are cutting less treble and any feedback issue will be worse.
This is not good pedal for spaghetti wiring with in and out all twisty. You may even want to try it first without a stomp switch just to confirm it is working, *always* a good idea.
snow123
Quote from: idy on August 10, 2021, 11:05:45 PM
well everything else works as it should tho
aron
It's usually input and output wires too close together along with too much gain. I've used shielded cable and it seems to help a lot.
snow123
im gonna replace the output wire since its just 2 wires soldered and heatshrinked together.
snow123
Quote from: snow123 on August 10, 2021, 11:42:32 PM
just replaced it and nothings changed.
aron
antonis
Any bulk patch guitar cable will do the job.. :icon_wink:
Additionally, you may raise 100pF cap up to 150pF..
mdcmdcmdc
That oscillation issue in Rats is pretty common. Some people have luck by increasing the 30pF to 100pF or larger (that's never actually worked for me), but the only thing that's ever solved the issue in my experience is a buffer in front of the pedal. If you have a boss pedal kicking around, stick it in front of the rat clone in your chain and see if the oscillation stops.
mdcmdcmdc
There's a good chance that whatever the core issue happens to be is being exacerbated by dint of this being a vero layout, with signal crisscrossing around and everything kind of out in the open rather than a nice and tidy PCB. That said, I have about 3 or 4 proco rats sitting in a box waiting for me to get around to "fixing" them that all do this. I'm not sure if there's actually a means to troubleshoot other than replacing every cap and the IC.
It may also have something to do with the mains/wiring in your house, as I have at least one wonky one that will self oscillate at my apartment but not at my practice space.
" I will say no more "
Phend
Quotei get a high pitched squeal
R U running this thru a Pignoze amp ?
  • SUPPORTER+
Do you know what you're doing?
snow123
Quote from: antonis on August 11, 2021, 05:32:29 AM
so push back cloth wire should be fine?
snow123
Quote from: Phend on August 11, 2021, 02:30:55 PM
nope an orange micro dark lol
mdcmdcmdc
Are you using an LM308 and have you tried swapping out a different IC? Looks like you socketed it.
r080
That wire should be fine, as long as you ground the shield.
I think the point was you can use whatever you have, even just the cable from a cheap patch cable.
Rob
snow123
Quote from: mdcmdcmdc on August 11, 2021, 03:09:43 PM
yes, I'm using an lm308, and i tried swapping it for a ua741 and tl071 and nothings changed.
kaycee
Quote from: duck_arse on August 11, 2021, 11:22:15 AM
hey! are we getting the band back together?
Only 15 pages to go till resolution.
I'm convinced this is RG having a larf  :icon_lol:
