Variable Line Out Box help ?
Started by Soulchief, August 17, 2021, 12:22:38 PM
Soulchief
Variable Line Out Box ?
I ran a search and I know this has been talked about in various ways but a lot of the links are dead..
Could anyone layout how to make a 'Variable Line Out Box with a Ground Lift switch' for various tube amps up to 100watts to route to a WET Rig? I don't need any cab simulation..
   Thru Speaker Jacks
   Potentiometer
   Line Out Jack
   Ground Lift Switch?
I do understand they are NOT Load boxes and must have speakers connected.
I just don't know about values..
I see some people mention output impedance of the Line Out making them really low (under 1K) and some say 10K.. ?
I'm just looking for variable level control, transparent line out, and a possible ground lift incase needed.
Thanks for any help
If you need a ground lift, then you need a transformer.
Soulchief
^ ^ ^  Oh that's right... forgot about that.
How 'bout still basic as described but no 'Ground Lift'?
Thank you again
