Modify FreakZEQ parametric for bass?
Started by theehman, August 17, 2021, 01:25:52 PM
theehman
Bought the PCB and built it but I was hoping to use it on bass and it just doesn't work that well in the bass range.  I was wondering if someone with a better knowledge of filters could point out what to change to make it more bass friendly.  Schematic attached.
Ron Neely II
fx schematics and repairs
Vivek
I suppose you could first try different cap values for
C8
C9
C10
C11
Vivek
Do you have a Bass EQ pedal ? If yes, what are your favorite settings ?
theehman
Quote from: Vivek on August 18, 2021, 04:15:54 AM
I don't have an eq pedal at the moment
Ron Neely II
Vivek
I dont have any experience in the requirements to EQ a bass sucessfully
besides the general notion that most important frequencies are much lower than those of a guitar
I can suggest normal idea of changing those caps that determine frequency, to lower them.
But maybe Bass has more requirements than just change the frequencies. For example, Bass might need more control bands.
But tell me, when you start to move your knobs in the direction that gives you better sound, in which direction do you turn the knobs ? You want even higher Q or even lower Q ?
The user manual does say :  The frequency selection is infinitely variable from almost sub-bass frequencies to high frequency definition and edge. The selected frequency band can be as wide as 2 octaves or as narrow as a single note.
If that is true, I wonder what needs to be tweaked.
