Questions about arph's Sentinel Droneverb circuit
Started by moid, August 30, 2021, 06:10:06 PM
Locrian99
#20
Nice demo.  I'll for sure have to mess around with it when I get a chance.  Seems like my list of stuff to build is always growing lol.    If you like that one you should for sure check out the sea machine.  Here's a demo
https://youtu.be/M1beZYoh-_I
And the layout.
http://dirtboxlayouts.blogspot.com/search?q=Sea+machine&m=1
There's also a version over at tag board effects that uses 2 72's instead of the 74.
moid
Ooo that's a nice demo, I like the sound of that pedal! Which layout did you build? Is there any benefit from using TL074s or TL072s? I know what you mean about a build list, mine I am sure breeds when I am not looking at it!
Mushrooms in Shampoo -  Amidst the Ox Eyes - our new album!
https://mushroomsinshampoo.bandcamp.com/album/amidst-the-ox-eyes
your first two minutes sounds to me a lot like a David Lynch soundtrack, moidy.
" I will say no more "
Locrian99
Quote from: moid on August 27, 2022, 07:35:00 AM
I did the 74 version because it's a little smaller and has a couple fewer cuts and links.... It's big enough as is for vero.   The eqd version oscillates a bit more than the clone version.   There's a couple little easy changes you can make to change that and to get a vibe switch.
moid
Quote from: duck_arse on August 27, 2022, 10:51:56 AM
Thanks Duck! I'll definitely take that as a compliment; now I need to explain to moid junior (who played the guitar) who David Lynch is...
Quote from: Locrian99 on August 27, 2022, 12:27:22 PM
Thanks! I will bear that in mind... I doubt I will start on that this Summer, I've got another chorus pedal under construction at the moment but it's definitely something for next Summer!
sit moid jnr down in front of Eraserhead. learn him some cultcha.
moid
I suspect that Mrs Moid would have some very negative opinions about that, Moid junior is too young for that sort of film!
moid
Look! I finished something! Here is the final pedal in all it's glory...don't look too hard at the textured sides, that's to make it easier to grab hold of!
top down
underneath
Really pleased with the swirly abstract mess effect; did that last year with acrylic paints; originally it dripped down the sides which didn't look so good, covering it in white is better even if it is rather lumpy!
