Electro Harmonix Clone Theory (Doubts about construction and layout)
Started by Pedroga, September 08, 2021, 07:49:01 PM
Pedroga
hello everybody, so... I intend to build a Chorus/Vibrato pedal (Electro Harmonix Clone Theory) ''the Peter Hook pedal''.
I am in doubt as to how I will do with the power supply of this pedal (The layout says but I don't understand) This pedal originally has a cable to connect directly to the power without batteries or batteries.
The layout tells me to build the power daughter board, can someone explain a little bit about how I should build it perfectly?
Here is the pedal link:
https://tagboardeffects.blogspot.com/2014/05/electro-harmonix-clone-theory.html
Would I have to use a transformer or source?
The effect needs a 15V supply so you can either use a standalone 15V adapter if you have one, or build the included power daughterboard which with double the supply and then uses a regulator to reduce it to a stable 15V.
idy
If you have a (regulated) 15v power supply, you can use it. You can also use a normal 9v supply and the daughter board which will up that for you and regulate it to 15.
But I would add as a pal that if that was in doubt, this is not a good first project for you now. But....
...welcome to the forum!
PS: if you did have a regulated 15v supply, the smart guy would still add a few items like "reverse polarity protection" to the board.
Yes, the original had a "mains cable" and as "transformer," and the fellows at FX Layouts made a version that is less likely to electrocute careless noobs.
I have successfully built a couple Clone Theory pedals using that same layout, including the charge pump daughter board.  Nearly every modern pedal uses a 9VDC power supply, and the daughter board allows you to use the same for this one.
FYI, there is an incorrect cap value in that layout, I believe (not related to the power supply stuff). Let me check my notes...
Edit:  Here it is, courtesy of Scruffie, who traced of the circuit:
QuoteThose 680pF caps should be 412pF by the way, Tagboard used an outdated schematic of mine, parallel a 390pF & 22pF.
Pedroga
Quote from: EBK on September 08, 2021, 09:12:27 PM
Do you have the updated schema?
Pedroga
Quote from: idy on September 08, 2021, 08:59:33 PM
I have this transformer, can I use it?
If I use it I won't need the daughterboard right?
Quote from: Pedroga on September 09, 2021, 09:05:23 AM
Of course but you'll also need a 7815 style voltage regulator..
(you know, full-wave rectification, reservoir capacitor, regulator In-Out caps, etc..)
Pedroga
Quote from: antonis on September 09, 2021, 09:10:15 AM
I saw a photo that it is placed directly on the board.
How do I put this voltage regulator? it looks like a transistor
Pedroga
A schematic of this updated pedal would be of great help to me, as I'm not an electrical engineer. If you have I would be very grateful.
I'm just a guy wanting to play Joy Division and New Order
Look here for Scruffie's schematic:
https://www.diystompboxes.com/smfforum/index.php?topic=105743.0
That schematic just assumes you have a 15VDC supply.  I personally wouldn't build a power supply with a transformer into the pedal if you aren't experienced with such things.  The 9V-to-15V charge pump is fairly simple, and 9VDC wall warts are cheaply available.
Quote from: Pedroga on September 09, 2021, 09:45:10 AM
It looks more like a TO-220 IC.. :icon_wink:
https://www.componentsinfo.com/lm7815-pinout-equivalent-circuit/
P.S.
On a second thought, I'm not sure you have the skills to deal with mains supply, so PLZ don't do it..!!
Pedroga
Quote from: antonis on September 09, 2021, 10:07:23 AM
P.S.
I've built guitar amps and bass, I've never built pedals so I have so many doubts about that. But thank you very much for the answers friend
Pedroga
Quote from: EBK on September 09, 2021, 10:05:11 AM
Is this scheme 100% correct?
I will build it this year yet.
thank you very much friend
