RG Keen Mini Mixer not muting sound source at full ccw ?
Started by Nicotep, September 12, 2021, 04:20:30 AM
Nicotep
Didn't find a previous topic about that, despite the huge amount of discussions about RG Keen's mixer...
With specific sources (ie Teenage Engineering's OP-Z), I still have (little) audio passing through at full CCW, though OP-Z has a 'normal' output I believe, not especially loud.
(I have to specify I replaced R13 by a 250k pot to get some extra dBs on the master, if needed).
Is there a way to mute completely the audio when pot's at minimum ?
With the control completely CCW, the input should be grounded, so there shouldn't be any signal coming through.
It sounds to me like you've got a cr4p pot that doesn't go completely to zero.
E.D.'s got a good point. Some pots don't go fully to the end of the electrical resistance by the time the mechanical rotation stops. I've run into this many times. It's a function of the mechanics of the pot. If you happen to have an pot of a different style/brand, try that and see if it helps.
stallik
And some pots go past the end! I've got one on a guitar that catches me every time. Turn down to 1% - silence. A little but further down to 0% and I get full volume again. CTS pot so nothing unusual. I've probably been buying fakes again ;)
