Simple EQ CabSim / custom curve
Started by VoivoD, October 17, 2021, 09:57:28 AM
VoivoD
Hey, I'm looking around something like Simple CabSim v2, but with a different eq curve. The curve is not final, however for now it works well for me. Any help with modifying the original Cabsim v2, to fit the eq filters mentioned below?
HP 40hz -12db/oct
Peak 600hz, -4db, Q=0.7
LP 4khz, -12db/oct
I might consider using more resonant ones on HP & LP, so could be with a switch.
GibsonGM
Welcome, VoivoD.....Might get some action if you can post a schematic of the circuit you want to modify?
Vivek
Normally these schematics have to be tweaked on a simulator since all filters interact with each other.
Do look at following Cab Sims that have somewhat similar response :
http://www.runoffgroove.com/condor.html
Cream machine and Boss tm3 from https://www.hexefx.com/diy/tech/cabsims
They could possibly be good starting points
