BRETT MILLER DS 1 “MONDO-MIJ” MOD question
Started by eh la bas ma, October 18, 2021, 12:21:49 PM
eh la bas ma
Hi,
I am trying to do this mod. I wonder if I can use 1uf electrolytic caps on C8 and C14.
Instructions says "metal film" caps but there are polarized caps on my DS1 board...
Thanks for your help !
https://www.diystompboxes.com/DIYFiles/up/Build_Your_Own_DS-1_Distortion.pdf    p.18
Edit: I guess I can answer my own qustion : No, the idea is to change the type of caps, values are the same. I only have these :
Is there any interest changing 1uF electrolytics for them ?
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
antonis
IMHO, stay away from tantalum caps.. :icon_cool:
(big grey box cap should be OK..)
eh la bas ma
#2
Thanks, it fits in the enclosure easily.
I am tryng to build the diode  section (p.21). My usal suppliers don't have 2n3859, any idea if  2n4401 will work here ?
Looks like i really need a smaller B100k, a regular one won't fit. I drilled the pot location on "dist"...
eh la bas ma
#3
I received a small B100k pot and I finally finished this mod (on a real DS-1).
https://www.diystompboxes.com/DIYFiles/up/Build_Your_Own_DS-1_Distortion.pdf    p.21
I am using a 2N3053 instead of 2N3859A (out of production I guess). I left the collector leg empty.
Everything sounds fine, but I wonder if it's ok if none of the 3mm red leds lights up at any setting ?
Should I do something with the 2N3053 collector leg ?
Any advice would be welcome !
idy
You can't always see LEDs light up when they are clipping. Extremely dim usually. Maybe in the dark with a heavy boosted signal, max gain...flicker.
